Hello i have trouble with seting up multicasting in my X440-X460 switches. I can ping every device in network, but Video is not showing under my WorkStation or isnt recorded. I have run wireshark on my Workstation sniffing for multicast trafic but no trafic was found. How to diagnose this situation. (Windows firewal is diabled)
Run Wireshark on the workstation affected.
Click Capture > Interfaces > Place a check mark next the Endura NIC > Click Start > Let the capture run for a minute > Click Stop.
In the display filter type udp.dstport==2901 then click Apply.
If the workstation is receiving multicast traffic from the System Manager your output will look like the sample below. If it does not contact your network administrator.
http://buildingskb.schneider-electric.com/casefiles/12770/udp.dstport.2901.png
Network topology
![97fb0c80d45143609a40e0436fca35df_RackMultipart20160426-110425-1y6muhm-usunmnie_inline.jpg 97fb0c80d45143609a40e0436fca35df_RackMultipart20160426-110425-1y6muhm-usunmnie_inline.jpg](/t5/image/serverpage/image-id/3305i02169AC161CD2FE0/image-size/large?v=v2&px=999)
Bud_1-X460.2 # show port utilization bandwidth Port Link Link Rx Peak Rx Tx Peak Tx State Speed % bandwidth % bandwidth % bandwidth % bandwidth ================================================================================ 1 A 100 0.00 0.00 0.00 0.02 2 A 100 0.00 0.00 0.00 0.02 3 A 100 0.00 0.00 0.00 0.02 4 A 100 0.00 0.00 0.00 0.02 5 R 0 0.00 0.00 0.00 0.00 6 A 100 0.00 0.00 0.00 0.02 7 A 100 0.00 0.02 0.00 0.01 8 A 1000 0.00 0.00 0.00 0.00 9 A 100 0.80 0.80 0.00 0.01 10 A 1000 0.40 0.40 0.00 0.00 11 A 100 1.39 1.76 0.01 0.01 12 A 100 1.33 1.33 0.00 0.01 13 A 1000 0.00 0.22 2.88 2.88 14 A 1000 0.30 0.45 0.00 0.00 15 A 1000 0.00 0.01 0.00 0.54 16 A 100 4.54 6.36 0.00 8.77 17 R 0 0.00 0.00 0.00 0.00 18 R 0 0.00 0.00 0.00 0.00 19 R 0 0.00 0.00 0.00 0.00 20 A 1000 0.00 0.00 0.00 0.00 21 R 0 0.00 0.00 0.00 0.00 22 R 0 0.00 0.00 0.00 0.00 23 R 0 0.00 0.00 0.00 0.00 24 R 0 0.00 0.00 0.00 0.00 25 A 1000 1.91 1.91 0.00 0.02 26 R 0 0.00 0.00 0.00 0.00 27 R 0 0.00 0.00 0.00 0.00 28 R 0 0.00 0.00 0.00 0.00 29 NP 0 0.00 0.00 0.00 0.00 30 NP 0 0.00 0.00 0.00 0.00 ================================================================================ > indicates Port Display Name truncated past 8 characters Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
Hints from Pelco:
- Does the selected switch support an appropriate number of Internet Group Management Protocol (IGMP) entries for the installation? It is important not to exceed the number of IGMP entries the switch can handle, because it will either block multicast traffic or flood multicast traffic when these limits are exceeded.
Bud_21-X440.16 # show config # # Module devmgr configuration. # configure snmp sysName "Bud_21-X440" configure sys-recovery-level switch reset # # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-24 configure vr VR-Default add ports 1-24 configure vlan default delete ports 1-24 create vlan "managment2" configure vlan managment2 tag 100 create vlan "v1-KD" configure vlan v1-KD tag 10 create vlan "v3-CCTV" configure vlan v3-CCTV tag 30 create vlan "v4-SCADA" configure vlan v4-SCADA tag 40 configure vlan managment2 add ports 23-24 tagged configure vlan managment2 add ports 20 untagged configure vlan v1-KD add ports 23-24 tagged configure vlan v1-KD add ports 1-4 untagged configure vlan v3-CCTV add ports 23-24 tagged configure vlan v3-CCTV add ports 5-16 untagged configure vlan Mgmt ipaddress 192.168.10.21 255.255.255.0 # # Module fdb configuration. # # # Module rtmgr configuration. # # # Module mcmgr configuration. # # # Module aaa configuration. # configure account admin encrypted "w57pp4$GwwfA/PzMpfpfYS0fq3XK0" Press to continue or to quit: # # Module acl configuration. # # # Module bfd configuration. # # # Module ces configuration. # # # Module cfgmgr configuration. # # # Module dosprotect configuration. # Press to continue or to quit: # # Module dot1ag configuration. # # # Module eaps configuration. # # # Module edp configuration. # # # Module elrp configuration. # # # Module ems configuration. # # # Module epm configuration. # # # Module erps configuration. # # # Module esrp configuration. # # # Module ethoam configuration. # # # Module etmon configuration. # # # Module hal configuration. # # # Module idMgr configuration. # # # Module ipSecurity configuration. # # # Module ipfix configuration. # # # Module lldp configuration. # # # Module mrp configuration. # # # Module msdp configuration. # # # Module netLogin configuration. # # # Module netTools configuration. # # # Module poe configuration. # # # Module rip configuration. # # # Module r.png configuration. # # # Module snmpMaster configuration. # # # Module stp configuration. # configure mstp region 00049698acd8 configure stpd s0 delete vlan default ports all disable stpd s0 auto-bind vlan default enable stpd s0 auto-bind vlan Default # # Module synce configuration. # # # Module telnetd configuration. # # # Module tftpd configuration. # # # Module thttpd configuration. # enable web http # # Module vmt configuration. # # # Module vsm configuration. #
