Power cables for SSA switches.
Brian_Onstott
Customer needs 15' power cables and the standard length is 6'. Having issue trying to determine length of power cables from the part number description. Have already looked at the power cord document and the price list, but no mention of lengths. Figured easiest way to do this is have customer purchase third party cables with specification listed.
2 REPLIES 2
Drew_C
Valued Contributor III
Hi Brian,
I believe Brandon is correct - we only sell the standard 6' power cables. For anything "specialty" in our labs, I usually buy from stayonline.com or monoprice.com. Between those two, you'll find everything you need.
BrandonC
Hi Brian,
Looking over the price list, I do not see any cables other than the 6' ones. I'll double check, but since you need 15' cables, third party may be the best option.
-Brandon
