Problems with rate-limit flood unknown-destmac causing slow traffic
javfe
New Contributor III
We have detected that some users are experiencing slow traffic, specially while they are uploading files to a shared server (located in the same vlan as the computer or in different vlan). They upload the files both via Windows smb or via sftp. Once they start to upload the files we have detected that after a while the “Unknown-dest-mac flood” counter increases dramatically and the switch reach the rate-limit configured (1000 pps in the UP-LINK port and 120 pps in the users ports) and so it starts to drop packets, causing the slowness in the traffic and uploads.
Regards
Javier
1 ACCEPTED SOLUTION
StephanH
Valued Contributor III
Hello javfe,I think the categorization is not the problem. You have to check different causes. One if them are the server ports. Here are some other hints:
Regards Stephan
7 REPLIES 7
javfe
New Contributor III
Hello Stefan,
I don’t know the status of the server. No problems are identified in the traffic captures
StephanH
Hello javfe,
if your server has more then one network interface, as first steprepeat the test with only one enabled.
Regards Stephan
Stefan_K_
Valued Contributor
Is the server virtualized?
Do you see anything strange in Wireshark on the client?
