02-23-2023 10:58 AM
Good day all,
Further to the subject, I have an extreme x465-24w switch with a vim5-2y module installed (port 25). I'm using an Extreme SR SFP+ 850nm module to connect to an extreme x460 switch (using the same sfp module). The port lights on both switches show activity and I can visibly see the beam on both switches however there is no connectivity between devices (using MM cable).
Steps taken:
configure port 25 partition 4x10GE.G. "configure ports 29 auto off speed 10000 duplex full"
So far the sfp shows as supported on both switches, however it only shows a signal as present on the x460 switch when running "debug hal show optic-info port 25".
Does anyone have any ideas how I can get this working?
03-20-2023 01:45 AM - edited 03-20-2023 09:22 PM
Looking forward for solution. MyCoverageInfo
04-24-2023 07:20 AM
Unfortunately I haven't found a solution as yet.
04-24-2023 12:20 PM
Solution: Upgrade firmware from IMG 30.2.1.8 to 32.4.1.10.
