vlan configuration for routing unable to ping own subnet
Rasheed_Folami
New Contributor II
Hi guys, First of all, I'm really new to this and have been stumbling through to figure out a nagging issue
We created 4 VLANs with corresponding Virtual Routers (as well as separate subnets) in our brand new environment (Users,Server, Lab,Phone). One of our VLANs ("User") is the only one currently utilized. It is on a 10.1.15.x subnet (part of a B5 stack) seems to be restricting certain computers from accessing the internet. Most of the other client computers (on same subnet) are able to access the network and internet, with the exception of a few. The VLANs were setup last weekend, and I believe it may be a configuration issue.
The affected clients receive IP via DHCP and are able to get IPs;
IP: 10.1.15.x
Subnet Mask: 255.255.255.0
Gateway: 10.1.15.254
but are unable to ping the internal VLAN gateway (10.1.15.254). They can ping any IP on the same subnet (and vice versa) but are unable to ping any other IP on other subnet (the unnafected computers on same subnet are able to ping other subnets just fine, and have no problems connecting to internet).
I suspect some sort of MAC blocking?? It happens no matter what active port i try them on.
Any assistance in troubleshooting is hugely appreciated. We have had no luck figuring it out.
12 REPLIES 12
Jeremy_Gibbs
Contributor
Just a quick question, tg.2.50 and tg.1.50 go to what? Other switches connected to it? Who is doing the routing? Enterasys, Cisco, Extreme? I know the B5 doesn't do L3 interfaces.
Rasheed_Folami
New Contributor II
Hi Jeremy, here it is
B5(su)->show port egress
Port Vlan Egress Registration
Number Id Status Status
ge.1.7 15 untagged static
ge.1.9 15 untagged static
ge.1.23 15 untagged static
ge.1.27 15 untagged static
ge.1.31 15 untagged static
tg.1.50 1 untagged static
tg.1.50 9 tagged static
tg.1.50 15 tagged static
tg.2.50 1 untagged static
tg.2.50 9 tagged static
tg.2.50 15 tagged static
B5(su)->show vlan static
VLAN: 1 NAME: DEFAULT VLAN
VLAN Type: Default
Egress Ports
tg.1.49-50, tg.2.49-50, lag.0.1-6
Forbidden Egress Ports
None.
Untagged ports
VLAN: 5 NAME: Server
VLAN Type: Permanent
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 7 NAME: iSCSI
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 9 NAME: Voice
Egress Ports
tg.1.50, ge.2.1-48, tg.2.50
None.
Untagged ports
ge.2.1-48
VLAN: 11 NAME: Finance
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 12 NAME: MGMT-HR
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 15 NAME: Users
Egress Ports
ge.1.1-48, tg.1.50, tg.2.50
None.
Untagged ports
ge.1.1-48
VLAN: 20 NAME: VPN
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 25 NAME: Lab
Egress Ports
None.
None.
Untagged ports
None.
VLAN: 30 NAME: Testing
Egress Ports
None.
None.
Untagged ports
None.
Rasheed_Folami
New Contributor II
No, no policy in place
Jeremy_Gibbs
Contributor
Well, show us this please:
show port egress
show vlan static
Jeremy_Gibbs
Contributor
I am assuming you are not doing policy, right?
show policy profile all should show nothing.
