10GBASE-LR/LW XFP problem
Alexandr_P
Valued Contributor
Hi, colleagues!
Have esome strange issue:
X460-48x
XGM3s-2xf
install 10GBASE-LR/LW XFP modules, connect them with optic patch and ports not up.
Try with other XGM3S-2xf, try with other transceivers, with other optic patchcord - nothing help.
Some outputs:
#deb hal sh op
Port 49Media Type XFP_LR
XFP Vendor: OEM
XFP Part Number: XFP-10G-LR
XFP Serial Number: S1106013011
XFP Revision: A
Date Code: 110819
Transceiver Type: XFP
Connector: LC
10GE Compliance: 10GBASE-LR/LW
XFP Supported: no
# sh ports 49-50 configuration no-refreshPort Configuration
Port Virtual Port Link Auto Speed Duplex Flow Load Media
router State State Neg Cfg Actual Cfg Actual Cntrl Master Pri Red
49 VR-Default E R OFF 10000 FULL !XFP_LR
50 VR-Default E R OFF 10000 FULL !XFP_LR
Any thoughts?
Thank you!
12 REPLIES 12
Alexandr_P
Valued Contributor
Hi, Drew!
I using dual fiber SM opatic patch-cord 1 and 2 meters.
Also tryed 1 port is non-original transceiver, second port - Extreme's transceiver.
I'm concerbed below output with abnormal parameters:
Port Temp TxPower RxPower TxBiasCurrent Voltage-Aux1/ Voltage-Aux2 (Celsius) (dBm) (dBm) (mA) Vcc (Volts) (Volts)
49 32.50* -40.00* -40.00* 2.00* 3.29 N/A
50 37.34 -1.74 -24.09* 37.80 3.35 N/A
Thank you!
Drew_C
Valued Contributor III
I think we should test this in the lab with some LR XFPs. We've got a few different manufacturers' models - all Extreme Certified.
Alexandr, what length and type of fiber cable are you using? I'm wondering if it is possible that they are shutting down because the signal is too strong.
Alexandr_P
Valued Contributor
If you mean EXOS - trying with 15.4, 15.6, 15.7
Patrick_Voss
Can you provide me with the version of code you are running?
Alexandr_P
Valued Contributor
That's not Extreme's optics.
In "H/S-ware-compatibility" document this optic is supporting.
Log only that LR_XFP is inserted
