10-19-2020 01:54 PM
I’m having an issue with a fiber connection between a 440-g2 and a B5 switch in the same building. Everything was fine then the connection between the 2 were lost unexpectedly. All other devices plugged into the 440-g2 on vlan 1 works fine.
After several hours of troubleshooting, I was able to create a strange workaround by plugging in a spare B5 into the 440-g2 via an ethernet cable (nothing else is plugged into the spare B5), now I can ping across the fiber from the 440-g2, not sure why though.
Does anyone have any ideas why the fiber only works with another B5 is plugged into the 440-G2?
Solved! Go to Solution.
10-19-2020 05:26 PM
Stefan,
You pointed me in the right direction and I believe it is now able to communicate without the additional B5 switch being connected. Had to enable STPD on the 440-G2 for the port using the fiber connection.
Here are the commands I ran to fix it.
configure stpd s0 ports link-type edge <port connected to fiber>
configure stpd s0 ports edge-safeguard enable <port connected to fiber>
configure stpd s0 ports bpdu-restrict enable <port connected to fiber>
enable stpd s0
I’ll keep an eye on it and see if any other issues arise with this configuration. If I run into issues, I’ll update the thread.
10-19-2020 05:26 PM
Stefan,
enable stpd s0
10-19-2020 02:59 PM
Hi Stefan,
Thanks for taking time to reply. STP is disabled on the 440-g2, but is enabled by default on the B5’s so that would make sense on why plugging in the B5 to the 440-g2 works. I’m still unsure on why the original connection stopped working though and still investigating, with my limited knowledge on 440-g2’s. Any help is appreciated.
10-19-2020 02:37 PM
Hello,
do you maybe use spanning tree and plugging in the B5 initiated a spantree topology change, which fixed a STP-problem, that blocked the downlink-port to the B5?
