Hi,  I have an ACL defined to manage general access between subnets across switches, and as part of that some rules have counters assigned to them.  The problem I am having is that when I use the show access-list counter command, not all of my counters are showing and I get a list that lookes similar to the below :
# show access-list counter
Policy Name       Vlan Name        Port   Direction
    Counter Name                   Packet Count         Byte Count
ACCESS_CONTROL    *                *      ingress
    Rule1                                           163
    Rule2                                           0
    Rule3                                           0
  not well-formed (invalid data)
if anyone can help I would like to know why it says "not well-formed (invalid data)"
 Also if anyone has experience with defined counters not appearing...
i have compared ACL defined rules and cannot see any obviuos syntax differences between rules where the counter works and rules where it does not..  i havwe working counters and non working counters from rules both pretty much identical to the below:
entry Rule1 {
    if {
        source-address x.x.x.x;
        destination-address y.y.y.y;
    then {
        permit;
           count Rule1-Counter;
Any comments appreciated
Thanks
