Hi Ron,
I may be misunderstanding your question, but you can actually put all CobraNet traffic into one VLAN, regardless of the port.
EXOS will allow you to configure two untagged VLANs on a port, assuming at least one has a protocol filter set up. In this case, we can create a protocol filter to match CobraNet, then create a CobraNet VLAN and add all ports untagged. Then, all CobraNet traffic will get put into this VLAN, while all other traffic will go into the other untagged VLAN. An example config is below:
create protocol cobranet configure protocol filter cobranet add etype 0x8819 create vlan cobra create vlan other_traffic configure vlan cobra protocol cobranet configure vlan cobra add port all untagged configure vlan other_traffic add port all untagged
Let me know if you have any questions.
-Brandon
