Add vlan to existing switch and ospf routing
Sidney_Yoder
Not able to ping new vlan default gateway
Name VID Protocol Addr Flags Proto Ports Virtual Active router /Total
corp_CTAP_agents 3710 10.131.82.1 /24 -f----------------------- ANY 0 /1 VR-Default
CTAP-Agent 500 192.168.112.1 /24 -f----------------------- ANY 80/132 VR-Default
Default 1 --------------------------------------------- ANY 0 /0 VR-Default
EVN 501 10.20.50.1 /24 -f----------------------- ANY 1 /3 VR-Default
IPC 502 172.16.50.1 /24 -f----------------------- ANY 1 /4 VR-Default
IVN 503 192.168.50.1 /24 -f----------------------- ANY 1 /7 VR-Default
Mgmt 4095 --------------------------------------------- ANY 0 /1 VR-Mgmt
XO_VPLS_MESH 1000 10.128.254.4 /24 -f-------o--------------- ANY 1 /1 VR-Default
VLAN Interface with name corp_CTAP_agents created by user
Admin State: Enabled Tagging: 802.1Q Tag 3710
Description: None
Virtual router: VR-Default
IPv4 Forwarding: Enabled
Primary IP : 10.131.82.1/24
IPv6 Forwarding: Disabled
IPv6: None
STPD: None
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
QosProfile: None configured
Egress Rate Limit Designated Port: None configured
Flood Rate Limit QosProfile: None configured
Ports: 1. (Number of active ports=0)
Untag: 3:44
20 REPLIES 20
Bill_Stritzinge
Sidney,
Not sure I have everything correct, but if you created the vlan corp_CTAP and need to ping the default route on the OSPF interface XO_VPLS_MESH, if you are using full dynamic routing you need to have OSPF enabled on the corp_CTAP vlan.. Can you show me the output of "show iproute" and give me a little more background on what it routing where?
Bill
