autonegotiation problem on X440-48t-10G
Mauran
hi, my problem is the tuning speed and mode on ports for old pc , this client works fine on old switch A2H124-48, when I try to connected same client on new sw (X440-48t-10G), the connection not work!!!
the led on the port with no connection is green, but the output console port is:
Port Display VLAN Name Port Link Speed Duplex# String (or # VLANs) State State Actual Actual
3:43 UfficiCup E R
10 REPLIES 10
Mauran
sorry ,my problem can be auto-bind of stpd s0?
It must be configured on all VLAN present on the switch?
Drew_C
Valued Contributor III
Mauro, At this point, I would suggest opening a case with GTAC so that this can be investigated further.
How to contact Extreme Networks Global Technical Assistance Center (GTAC)
Mauran
no ,with port disabled the LED stays green , and by command line State: R
Drew_C
Do the logs show any port becoming active when you connect and disconnect that link? If you disable it, does the LED turn off?
Prashanth_KG
Hi Mauro,
In addition to the LED status requested by Brandon, please also share the following output:
show port 3:43 configuration no-refresh.
When it was connected to the old switch, are you aware of the port speed and duplex settings on that switch when it was operational?
Looking forward to your response!
