ā01-09-2021 07:30 PM
Dear gents
i cannot find this command disable flow control commands in commands menu although it is written this command is supported from version 12.1.3 as mentioned in 30.2 reference guide
anyone know the reason ??
Solved! Go to Solution.
ā01-10-2021 12:27 PM
As far as I know there is no list regarding features not supported with GNS3. There is no official support for GNS3 issues with XOS and GNS3.
From https://github.com/extremenetworks/Virtual_EXOS:
āVirtual EXOS installations are not officially supported by GTAC and not all features and functions are implemented. Please visit us on The Hub if you have any questions or encounter issues.ā
So you are here on the right place. Maybe one of the Extreme guys here in the form has more information.
ā01-10-2021 09:05 AM
DDE_Server,
Not all features are available in qcow versions.
Some features are based on the capabilities of the ASICs of the ports and on the qcow this processor is not present.
Another example of features unavailable on the qcow is related to the availability of roles to be applied on the ports.
Mig
ā01-10-2021 01:20 AM
EXOS v 30.2.1.8
No as I described above this is not found
Please note this is qcow2 image used in EVE_Ng emulation software
ā01-10-2021 12:53 AM
Strange!
Which switch model is this? Do you have āenable flow-controlā available?
