changing slot number in stack
Gene_Fontanilla
On my current working stack, i have 2 x670v and 2x440. I added another 2 x670v to the stack, I want to change the slot numbers of the current 2 x440 to a different stack number. By doing this, will the config also adapt to the change? or would i need to reconfigure it?
Setup is:
x670v <- Slot 1
x670v <- Slot 2
x670v <- Slot 5
x670v <- Slot 6
x440p <- Slot 3
x440p <- Slot 4
What i want:
x670v <- Slot 1
x670v <- Slot 2
x670v <- Slot 3
x670v <- Slot 4
x440p <- Slot 5
x440p <- Slot 6
28 REPLIES 28
PARTHIBAN_CHINN
Contributor
Easiest way to upgrade x440 's as standalone to the right partition and add it to stack again
PARTHIBAN_CHINN
Contributor
check if you have the below commands
download image image.exos partition slot 3/4
PARTHIBAN_CHINN
Contributor
you might have to load the image again to x440's so that it is loaded to the right partition
then reboot.
You should be able to do this slot by slot.
PARTHIBAN_CHINN
Contributor
Put the x440 in same partition as the x670 switches
This will solve ur problem
if you mean, all on secondary? it is already in it. if not, what do you mean? how do I do this?
