Combination ports on Extreme X480-48t
Miguel
Hello experts,
I am working now on a project that involves a switch extreme X480-48t, my question is about combination ports, this switch have 4 combination ports, i need to use the optical ports as a regular port, I mean, I need to add the port to a virtual router working with VRRP, it is possible?.
Thanks in advance for your help!.
5 REPLIES 5
Hi Paul thank you very much for your reply.
ok, let me know if I understand, i am quite working with extreme 🙂
I want to use all switch ports as normal ports, this combination port behavior can be disabled to achieve that? or to use the fiber port I have to disable to cooper port?.
Thanks!.
