computers lose connectivity after 15 minutes
‎05-25-2017 12:36 PM
Hello, 2 computers on same subnet can see each each other or can ping but after 10 to 15 minutes they lose the ping and no connectivity is seen between them.. there is no configuration on switch all ports are in default vlan. it is happening with 4 switches right now.
switch is X440 G2
XOS is 21.1.1.x
switch is X440 G2
XOS is 21.1.1.x
7 REPLIES 7
‎05-26-2017 07:56 AM
Please check the "show configuration vlan" after the issue occurs and see if flooding is disabled.
Then you are hitting the issue mentioned in the below article, this issue is fixed from 21.1.1.4 patch 1-5
https://gtacknowledge.extremenetworks.com/articles/Solution/Traffic-is-filtered-by-the-switch-with-d...
Please note that the current recommended version for X440-G2 is EXOS 21.1.3.7
http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/softwa...
‎05-25-2017 01:12 PM
static IP and there is no conflict between them.
‎05-25-2017 01:05 PM
static ip-s or DHCP?
