Configuring Exos Virtual Box
Manish_S
I am trying to setup my lab environment, with virtual box 4.3.26. I have uploaded the virtual box extension pacl. I have downloaded the EXOS VM, but when ever I try to import the VM the machine is not being listed in the folder specified.
This is the very first time I am using Virtual Box. Might be some dumb issue.
Had been couple of days that I have googled the issue, but couldn't resolve. Pls. help.
Regards,
Manish
32 REPLIES 32
The VM has a core license but, for some reason it also had a demo license installed.
Remove the demo licensewith the following command:
debug epm clear trial-license
After reboot the 30-day message will disappear.
dflouret
Manish, here's an OVA of the latest EXOS VM.
[list=1]
Download it and double-click the .ova file. Virtualbox will import it automagically...
Admin edit: See this article on where to download Virtual EXOS
Okay. Thanks Daniel
Again, no patch versions are produced for VM images. It just makes no sense...
Since many features don't work in the VM (i.e. VPLS), or work differently (LAG only supports round-robin, which is not available in physical switches), you can't use it to make sure a specific patch solves a certain problem in a specific configuration. You need to use real switches for that.
Thanks Drew and Daniel.But I need this patch for one of my devstack environment staging. Is there any way to get it ? kindly confirm. Currently I have
code:
vm-21.1.2.14.iso.
