create a 801.1q trunk on the fiber to connect the two switches
‎11-20-2014 04:12 PM
Hi Folks,
I'm trying to setup a vlan between a pair of summit 200/48's. So far I've got the vlan configured on both ends, I've configured the ports on both ends, and I'm stuck on creating a 801.1q trunk.
Can anyone point me in the right direction?
5 REPLIES 5
‎11-20-2014 04:17 PM
Hello tourless. You need to configure the VLANs with a tag using the command configuration tag . Then add your up link port to each VLAN as a tagged port using the command configuration add port tagged. Let me know if you need more help? P
