edge port using safeguard
shakil_khan
on my XOS switch i want to make ports 1 & 3 as edge ports would the below command syntax do the trick?
create stpd s0 configure stpd s0 mode dot1w
configure stpd s0 default-encapsulation dot1d
configure stpd s0 add vlan Data ports 1,3
configure stpd s0 ports link-type edge 1,3 edge-safeguard enable
enable stpd s0
9 REPLIES 9
PARTHIBAN_CHINN
Contributor
it should disable the port and enable it again after 5 minutes.
shakil_khan
configure stpd s0 port link-type edge 1,3 edge-safeguard enable bpdu-restrict
what happens if i put this recovery-timeout 300 command after the bpdu-restrict would it block the port and come to forwarding state after 300 secs (3mins)
PARTHIBAN_CHINN
Contributor
you have to enable BPDU-restrict on those ports.
shakil_khan
will the above command make them edge port? and if a device switch/hub is attached to port 3 will it go into blocking state?
PARTHIBAN_CHINN
Contributor
This is ok.
