EPS-500 External Power Supply Unit (Model 10911) compatibility with the Summit X440 48t and 48P.
‎07-16-2015 11:19 AM
Hi, Can anyone tell me if the EPS-500 External Power Supply Unit (Model 10911) is compatible with the Summit X440 48t and 48P. The pins look like they will connect but I just wanted to be sure.
6 REPLIES 6
‎07-16-2015 01:03 PM
Yes it is compatiable
Regards
Syed Arshad
Regards
Syed Arshad
Nope. My bad it doesn't i beleive. 440 support RPS-500p.
Apologies
Apologies
Have you used the EPS-500 successfully on one of your X440s?
‎07-16-2015 11:46 AM
Hi Sandeep,
EPS-500 External Power Supply Unit (10911) can be used for below models.
• Summit X150-24p switch
• Summit X250e-24p switch
• Summit X350-24t switch
• Summit X350-48t switch
• Summit X450a-24t switch
• Summit X450a-24x switch
• Summit X450a-48t switch
• Summit X450e-24p switch
• Summit X450e-24t switch
• Summit X450e-48t switch
Thanks,
Suresh.B
Thanks,
Suresh.B
