Is there a way to reset a port back to factory default. For instance if I have a port with 7 vlans tagged and 1 untagged with elrp on the port, how can I get the port back to just vlan default untagged without having to delete each vlan manually and disabling elrp manually. Thanks in advance!
For me port mirroring doesn't work, I get an error:
switch # enable mirror to port 10:33
Error: Port mirroring cannot be enabled on a trunk member port 10:33
Configuration failed on backup MSM, command execution aborted!
switch #
Anyone has an alternative idea how to change a tagged port to an untagged access port?
I also tried to delete it from all vlans, but it doesn't work.
