extreme summit x540a-24t looses configs after power cycle
natron
I have an extreme summit that looses configs when its power cycled. its a x450a - 24t
is there anyone who know this particular issue and how to resolve it ?
3 REPLIES 3
Tomasz
Valued Contributor II
Hi Natron,
The only thing I’d consider… How are you saving the config manually, just by ‘save’ or something more? The only behavior that could explain this IMO is if you had another cfg as your boot config (see “Config Selected” under ‘show switch) and been saving to another config file (‘save configuration anothername.cfg’) and refusing to use this another cfg as your default config when prompted.
Other than this, I’ve no idea. 😞
Does ‘ls’ show ‘autoexec.xsf’ existing?
Hope that helps,
Tomasz
natron
Saving manually, its an extreme summit x450a switch . sorry about the headline
Tomasz
Hi Natron,
I’m sorry for a stupid question, but to make sure: are you saving the config manually or is there auto-save feature enabled? What is the EXOS version running?
Kind regards,
Tomasz
