issue with X440-G2- 48P port problem
Zeenat_Ullah
Dear Extreme comunity,
I am facing problem with switch if i connect on 3 meter cable. Connectivity is fine then. But when cable's length varies suppose if length is 10 or 20 meter then there i am facing connectivity problem. What might be the exact problem.
Regards
6 REPLIES 6
StephanH
Valued Contributor III
Hello Zeenat,
what clients are on the "user" side?
What is the output from "show log" if the problem occurs?
Regards Stephan
Zeenat_Ullah
Command you ask about let me run that comand then i can share the results here with u
Zeenat_Ullah
Dear stephan,
When i restart the switch. Upto 2 minutes connectivity is Ok then after that time period again on user side port goes down while on switch end port status shows green!?
StephanH
Hello Zeenat,
can you describe “connectivity problems, please?
Did you check “show port <portnumber> txerrors / rxerrors?
Regards Stephan
