Extreme Switches Overview
JeremyClarkson
Do you know if there is a spread sheet or something similar that details the difference between all the switches, for example the difference between X430 vs X440.
I would like to provide the exact switch that is required without over compensating without knowing all the features of each.
Thanks
8 REPLIES 8
Paul_Russo
Hello ClassicD
All of our products are L3 switches except for the 430. Besides being a standalone switch, i.e. not stackable, it is also only L2. The 430 comes with L2 Edge license. The features support of all of licenses can be found in the Users guide in the appendix. Note that the 430 is an Edge switch. it has a lower CPU and lower Memory for value edge locations. The 440 is also an edge switch but allows for more functionality and the 460 is a switch that can go edge, distribution and core area.
If the switch starts with a 4 it is a 1G switch. If it starts with a 6 (like the 670) it is a 10G switch and if it starts with a 7 (770) then it is a 40G switch. the 460, 670, 770 all support up to the full core license with different table sizes.
I hope that helps. Please let us know if you have additional questions
P
Sumit_Tokle
Contributor
Drew, can you please share the updated comparison chart for all of us. It would help to quickly verify the features of all the devices at same page.
Thank you,
Drew_C
Valued Contributor III
That comparison chart seems to be quite outdated. Unfortunately, I'm not aware of a newer one.
Here's a feature support list, if that helps: http://learn.extremenetworks.com/rs/extreme/images/EXOS-DS.pdf
The X430 can be considered a "Summit Lite" device. It's a low cost, limited feature switch. Because of this, the X430 uses a separate EXOS image than the rest of the Summit lineup.
The X440 is a bit more powerful and supports a wider range of features. What kind of network implementation are you looking for?
In case you haven't seen it yet, the data sheets and other information for current products can be found on our website: http://www.extremenetworks.com/products
-Drew
JeremyClarkson
can you elaborate?
