‎10-21-2020 08:47 PM
I am upgrading some x620 switches. Right now they are running version 22.2.1.5-patch1-4. Am I able to go to the latest recommended release of 30.7.1.1-patch1-23 or would it best to stuck with the 22 version? Sorry for the newbie question…...Thanks.
Solved! Go to Solution.
‎10-21-2020 08:49 PM
Hi cback85,
The X620 will support the newer version, and there is no intermediate step--you can upgrade directly.
Thanks
Brad
‎10-21-2020 09:42 PM
Hello,
if you have problems upgrading directly to 30.7 install the latest 30.6 version and after that you should be able to install 30.7.
I had two X620 running 22.2.1.5 last week that I couldn’t upgrade directly to 30.7.1.1 Patch 23.
Best regards
Stefan
‎10-21-2020 08:51 PM
Thank you for the quick reply!
Hi cback85,
Thanks
Brad
