Hello. Please Help!! X460G2 is running with formware version 22.1.1.5.
Angel_Pavon1
New Contributor III
My X460G2 was rebooted and upgraded to firmare version 22.1.1.5. This was intermittent about six hours. Then I rebooted again and its up. But can u help me?... What does this los“ mean?
03/06/2017 02:10:22.37 Slot-1: EPM Started
03/06/2017 02:10:22.36 Slot-1: Booting after System Failure.
03/06/2017 02:10:22.26 Slot-2: Booting after System Failure.
03/06/2017 02:10:22.18 Slot-3: Booting after System Failure.
03/06/2017 02:10:21.25 Slot-1: Changing to watchdog warm reset mode
thanks.!!
9 REPLIES 9
Drew_C
Valued Contributor III
Angel, that release is very new and has not received any patches yet. There are a few issues with SSH that I believed are resolved in 22.2, but it also is quite new. That shouldn't be a deterrent, but rather something to consider. Check the release notes for each to review known issues.
Patrick_Voss
The fact that all 3 switches rebooted at the same time makes me believe that the power source needs to be looked into.
Tripathy__Priya
To me this is something found to be the switch lost power and this is either a power cable problem or the power supplying the switch went out throwing these log message later:
Angel_Pavon1
New Contributor III
Hi Patrick no I didn“t, just ther rebooted by itselve.
Patrick_Voss
Hello Angel,
Did you pull the plug on the switches?
