Help, I need to configure elrp
Susana_Tovar
New Contributor II
Hello All,
I need configure elrp in switch X460-24t version 16.1.4.2 patch1-7 but i don't know what option to choose, i have this options:
  • Log-and-trap disable-port egress permanent
  • Log disable-port ingress permanent
What is the difference between Log-and-trap disable-port egress permanent and Log disable-port ingress permanent
Thanks everyone for your help
1 ACCEPTED SOLUTION
That makes sense, all our user ports trunk voice vlan but not trunk for the data side. I appreciate the explanation.
20 REPLIES 20
Thanks with your answer 🙂
