how can i enable gui in X460 r X440
zain_mallick
how can i enable GUI in X440 X460....i m creating vlan and give ip and enable web hhtp..but not open gui interface...? plz guide me...this is my code
create vlan name
configuration vlan name tag name
configuration vlan name ipaddress 192.168.1.225 255.255.255.0
configruatoin vlan name add ports 4 untageed
enable web http
this is my code which i run in X460 summit extreme ,but not showing GUI interface...
and when i connect wire with port ,port light is not on...
6 REPLIES 6
zain_mallick
yes sir i enable all ports..
Karthik_Mohando
Hi Zain,
Can you make sure the port is not disabled.
You can use the command "show ports no-refresh" and see if the port state is enabled.
if not then use the command "enable ports " or all
