how to connect two switches via fiber cable(sfp port)
lokpoho
Hello guys,
I was able to configure one of the summit switch.I have also configure the second switch.
I want to be able to link the two switch together using fiber cable on sfp port
Thanks
1 ACCEPTED SOLUTION
jeronimo
Contributor III
Have you tried what happens when you connect them together? 🙂
I mean you have to learn by doing.
3 REPLIES 3
jeronimo
Contributor III
lokpoho
the first switch has 48 ports and there are more than 50 users so i want to use the other switch to connect together with the first switch to accommodate the users
jeronimo
Contributor III
What is the ultimate goal you want to achieve?
