We bought a Extreme Summit X440-24t switch and the idea is to replace a Cisco 3560 switch. I have no experience with XOS and there are two port configurations that I don“t know how to set up. These are the configurations on the cisco way:
## On these port how can I set up the port-security with MAC on ExtremeXOS
To answer the first part of your question you can configure MAC security by connecting the device to the relevant port (so the MAC address appears on that port) and then running the following:
create vlan test tag 450
configure vlan test add port 1 untagged
configure port 1 vlan test lock-learning
This will lock the MAC address on port 1 so no other MAC addresses can be used. You can also use 'limit-learning' to limit the number of MACs learnt to a certain number. 'unlock-learning' removes the lock and 'unlimited-learning' removes the limit.
I believe in Cisco, you need to configure "ip routing" command in order to enable routing. In same way, you could configure "enable ipforwarding " to configure that interface as L3
Thank you Sumit Tokle. In that case what you“re saying is that when I enable ipforwarding to a specific vlan X it turns those ports in that vlanX into a L3 routing ports? Because in my understanding a Vlan is a L2 usually.
