Slot-1 Stack.4 # sh configuration
# Module devmgr configuration.
configure snmp sysContact "
[email protected], +1 888 257 3000"
configure slot 1 module X440G2-48p-10G4
configure sys-recovery-level slot 1 reset
configure slot 2 module X440G2-48p-10G4
configure sys-recovery-level slot 2 reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-52,2:1-52
configure vr VR-Default add ports 1:1-52,2:1-52
configure vlan default delete ports 1:1-52,2:1-52
create vlan "CCTV"
configure vlan CCTV tag 10
configure vlan CCTV add ports 1:1-52,2:1-52 untagged
configure vlan CCTV ipaddress 10.3.0.5 255.255.0.0
# Module mcmgr configuration.
# Module fdb configuration.
# Module rtmgr configuration.
# Module policy configuration.
# Module aaa configuration.
configure account admin encrypted [snip]
# Module acl configuration.
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module exsshd configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
disable lldp ports 2:1
disable lldp ports 2:2
disable lldp ports 2:3
disable lldp ports 2:4
disable lldp ports 2:5
disable lldp ports 2:6
disable lldp ports 2:7
disable lldp ports 2:8
disable lldp ports 2:9
disable lldp ports 2:10
disable lldp ports 2:11
disable lldp ports 2:12
disable lldp ports 2:13
disable lldp ports 2:14
disable lldp ports 2:15
disable lldp ports 2:16
disable lldp ports 2:17
disable lldp ports 2:18
disable lldp ports 2:19
disable lldp ports 2:20
disable lldp ports 2:21
disable lldp ports 2:22
disable lldp ports 2:23
disable lldp ports 2:24
disable lldp ports 2:25
disable lldp ports 2:26
disable lldp ports 2:27
disable lldp ports 2:28
disable lldp ports 2:29
disable lldp ports 2:30
disable lldp ports 2:31
disable lldp ports 2:32
disable lldp ports 2:33
disable lldp ports 2:34
disable lldp ports 2:35
disable lldp ports 2:36
disable lldp ports 2:37
disable lldp ports 2:38
disable lldp ports 2:39
disable lldp ports 2:40
disable lldp ports 2:41
disable lldp ports 2:42
disable lldp ports 2:43
disable lldp ports 2:44
disable lldp ports 2:45
disable lldp ports 2:46
disable lldp ports 2:47
disable lldp ports 2:48
disable lldp ports 2:49
disable lldp ports 2:50
disable lldp ports 2:51
disable lldp ports 2:52
# Module mrp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
# Module ntp configuration.
# Module poe configuration.
# Module rip configuration.
# Module r.png configuration.
# Module snmpMaster configuration.
# Module stp configuration.
configure mstp region 0204969edd8c
# Module synce configuration.
# Module techSupport configuration.
enable tech-support collector
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
enable web https
# Module twamp configuration.
# Module vmt configuration.
# Module vsm configuration.
