‎09-26-2022 12:24 AM
Hello Community
Clients taking IP from the untagged vlan subnet as wanted but also Phones taking IP from the untagged vlan subnet. That shouldnt be like this.
In other vendor switches phones taking IP from the voice vlan with same config. Phone settings are default, auto negotiation and LLDP enabled.
Phone Model : SIP T46S
Topology connection is switch --> Phone --> Client
My switch config
Summit # create vlan voice
Summit # configure vlan voice tag 10
Summit # configure vlan voice add port 1,11-12 tagged
Summit # create vlan data
Summit # configure vlan data tag 11
Summit # configure vlan data add port 1 tagged
Summit # configure vlan data add port 5,11-12 untagged
Also i tried QOS config template but did not work either.
Summit #create qosprofile qp7
Summit #configure diffserv examination code-point 46 qp7
Summit #config dot1p type 6 qp7
Summit # enable diffserv examination port 1
Summit # disable dot1p examination port 1
Can somebody help me to figure out.
‎09-26-2022 04:46 AM
Do you have a nac?
Fast solution would be configuring static ips for the phones ? Would that be an option?
You could configure Routing between the two vlans. If you have a dhcp running in the phone vlan?
‎09-26-2022 05:43 AM
Thank you for reply
> No there is no NAC in the campus network.
> We cant manually configure the phones because so many of them in the network.
> There is no routing problem between dhcp server with vlans.
