‎10-25-2020 03:56 PM
I have an X440 and an X460-G2. They are connected in a Ring Topology and seem to be successfully stacked after following the guide on Extreme’s site. However, only the switch that is the master (currently my X440) has connection. If I plug a computer into a port on the X460-G2 I get no link lights and no network connectivity. If I make the X460 the master the connection works, but all devices plugged into the X440 lose their connections. I can see both switches from my master, but can’t log in to the non-master switch as it just sits at AAA-pending. The only thing I can think of is that the X460 is on Edge Advanced license while the X440 is on Edge. Any help would be greatly appreciated.
Solved! Go to Solution.
‎11-09-2020 02:03 PM
Sorry for the delay. After wiping both switches back to defaults again I updated them to the latest XOS that the X440 can support. Then after redoing all the stacking commands it seems to be working now. Thank you for your help with this.
I have them in a stack as I am going to move my NAS and VM hosts to 10-gig using the SPF+ on the 460-G2, but use the X440 for most of my regular 1-gig connections as it has more ports.
‎10-25-2020 05:23 PM
Is it even possible to stack X440(-G1) with X460-G2?
‎10-25-2020 04:27 PM
jveronese,
Please review the stacking steps.
Here the steps from my cheat sheet:
Mig
‎10-25-2020 04:21 PM
Sorry, I’m new to stacking, so I do not know how to tell if it is STP or EAPS.
This is a rough drawing of what I have. Stacking port 1 on 440 is going to port 2 on the 460, with port 1 on the 460 going to port 2 on the 440.
‎10-25-2020 04:06 PM
jveronese,
Something i not clear.
Are they in stacking or ring (STP or EAPS)?
A topology drawing could hep to understand
Mig
