Offcourse:
# debug hal show optic-info ddmi slot 2 port 37
Port 37
SFP or SFP+: SFP+
Signal: present
TX Fault: no
SFP/SFP+ Vendor: FLEXOPTIX
SFP/SFP+ Part Number: P.1396.10
SFP/SFP+ Serial Number: F820KJQ
SFP/SFP+ Manufacture Date: 160719
SFP/SFP+ Type: SFP/SFP+
Connector: LC
Type: LR
Supported: yes
Wavelength: 1310
GBIC supports DDMI. MonitorType: 68
Optic is Internally Calibrated
Temperature High Alarm : 95 C (0x5f00)
Temperature High Warning : 90 C (0x5a00)
Temperature : 24 C (0x1846)
Temperature Low Warning : -20 C (0xffffec00)
Temperature Low Alarm : -25 C (0xffffe700)
Temperature Status : Normal
Voltage High Alarm : 3800 V (0x9470)
Voltage High Warning : 3700 V (0x9088)
Voltage : 3306 V (0x812c)
Voltage Low Warning : 2900 V (0x7148)
Voltage Low Alarm : 2800 V (0x6d60)
Voltage Status : Normal
Tx Bias High Alarm : 90000 uA (0xafc8)
Tx Bias High Warning : 80000 uA (0x9c40)
Tx Bias : 28832 uA (0x3850)
Tx Bias Low Warning : 3000 uA (0x5dc)
Tx Bias Low Alarm : 2000 uA (0x3e8)
Tx Bias Status : Normal
Tx Power High Alarm : 1778 uW (0x4577)
Tx Power High Warning : 1412 uW (0x372d)
Tx Power : 559 uW (0x15df)
Tx Power Low Warning : 251 uW (0x9d0)
Tx Power Low Alarm : 199 uW (0x7cb)
Tx Power Status : Normal
Rx Power High Alarm : 1258 uW (0x312d)
Rx Power High Warning : 1122 uW (0x2bd4)
Rx Power : 641 uW (0x190e)
Rx Power Low Warning : 31 uW (0x13c)
Rx Power Low Alarm : 25 uW (0xfb)
Rx Power Status : Normal
Temperature High Alarm Int : 0
Temperature Low Alarm Int : 0
Temperature High Warning Int : 0
Temperature Low Warning Int : 0
Tx Bias High Alarm Int : 0
Tx Bias Low Alarm Int : 0
Tx Bias High Warning Int : 0
Tx Bias Low Warning Int : 0
Tx Power High Alarm Int : 0
Tx Power Low Alarm Int : 0
Tx Power High Warning Int : 0
Tx Power Low Warning Int : 0
Rx Power High Alarm Int : 0
Rx Power Low Alarm Int : 0
Rx Power High Warning Int : 0
Rx Power Low Warning Int : 0
exCalRxPower [0.000000] [0.000000] [0.000000] [1.000000] [0.000000]
exCalTx_Islope 256 exCalTx_Ioffset 256
exCalTx_PWRslope 256 exCalTx_PWRoffset 0
exCalTempSlope 256 exCalTempOffset 0
aux1 0 aux2 0
status 0x10
# show ports 2:37 information detail
Port: 2:37
Virtual-router: VR-Default
Type: SF+_LR
Random Early drop: Unsupported
Admin state: Enabled with 10G full-duplex
Link State: Active, 10Gbps, full-duplex
Link Ups: 9 Last: Mon Dec 12 15:51:00 2016
Link Downs: 8 Last: Mon Dec 12 14:59:51 2016
VLAN cfg:
Name: VLAN39, 802.1Q Tag = 39, MAC-limit = No-limit, Virtual router: VR-Default
Port-specific VLAN ID: 2007
Name: VLAN4000, 802.1Q Tag = 4000, MAC-limit = No-limit, Virtual router: VR-Default
Port-specific VLAN ID: 317, 318, 319, 320, 3001, 3002, 3003, 3004,
3012, 3013, 3026, 3031
STP cfg:
Protocol:
Trunking: Cfg master port is 1:37
EDP: Enabled
ELSM: Disabled
Ethernet OAM: Disabled
Learning: Enabled
Unicast Flooding: Enabled
Multicast Flooding: Enabled
Broadcast Flooding: Enabled
Jumbo: Disabled
Flow Control: Rx-Pause: Enabled Tx-Pause: Disabled
Priority Flow Control: Disabled
Reflective Relay: Disabled
Link up/down SNMP trap filter setting: Enabled
Egress Port Rate: No-limit
Broadcast Rate: No-limit
Multicast Rate: No-limit
Unknown Dest Mac Rate: No-limit
QoS Profile: None configured
Ingress Rate Shaping : Unsupported
Ingress IPTOS Examination: Disabled
Ingress 802.1p Examination: Enabled
Ingress 802.1p Inner Exam: Disabled
Ingress 802.1p Priority: 0
Egress IPTOS Replacement: Disabled
Egress 802.1p Replacement: Disabled
NetLogin: Disabled
NetLogin port mode: Port based VLANs
Smart redundancy: Enabled
Software redundant port: Disabled
IPFIX: Disabled Metering: Ingress, All Packets, All Traffic
IPv4 Flow Key Mask: SIP: 255.255.255.255 DIP: 255.255.255.255
IPv6 Flow Key Mask: SIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
DIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
Far-End-Fault-Indication: Disabled
Shared packet buffer: default
VMAN CEP egress filtering: Disabled
Isolation: Off
PTP Configured: Disabled
Time-Stamping Mode: None
Synchronous Ethernet: Unsupported
Dynamic VLAN Uplink: Disabled
VM Tracking Dynamic VLANs: Disabled
