LACP problem between Extreme network stack and Juniper VCP.
dilu
New Contributor II
We are currently facing a problem with a port sharing configuration.
On one end we have a X670 stack (2 switches) and on the other end we have two
Juniper switches in a virtual chassis (VCP).
The config is pretty straight forward. Extreme:
enable sharing 1:37 grouping 1:37,2:37 algorithm address-based L3_L4 lacp
Juniper:
xe-0/1/0 {
description "008";
ether-options {
802.3ad ae2;
xe-2/1/0 {
description "009";
ether-options {
802.3ad ae2;
ae2 {
description "to Mica IT";
aggregated-ether-options {
lacp {
active;
periodic slow;
The problem with this configuration is that port 2:37 (connected to port xe-0/1/0) frequently drops out of the LAG without the interface going down:
12/12/2016 14:59:51.01 Slot-1: Remove port 2:37 from aggregator
12/12/2016 14:59:51.00 Slot-1: Port 2:37 is Down, remove from aggregator 1:37
12/12/2016 14:59:51.00 Slot-1: Port 2:37 link down - remote fault
12/12/2016 14:59:26.39 Slot-1: Add port 2:37 to aggregator
12/12/2016 14:58:59.20 Slot-1: Remove port 2:37 from aggregator
12/12/2016 14:57:26.14 Slot-1: Add port 2:37 to aggregator
The things i’ve tried to fix this problem:
- Created a new LAG (ports 1:36 and 2:36) > no difference.
- Swapped the optics > no difference the problem still persists on port 2:37.
- Swapped fibers > no difference the problem still persists on port 2:37 but problem to the other port (xe-2/1/0) on the Juniper side.
The problem always seem to be on the "second" port on the Extreme stack.
Does anybody has any idea what could go wrong in the scenario?
10 REPLIES 10
Steven_Lin
Hi dilu,
Could you please provide the "show ports 2:37 information detail" and "debug hal show optic-info port 2:37 ddmi"output?
