11-05-2020 02:30 PM
11-05-2020 03:02 PM
Hi Peternoclue,
I think the issue is that you used “1:1-4:1”, which includes many many ports. Please adjust to “1:1,4:1” and see if that works better for you.
Thanks
Brad
11-05-2020 03:01 PM
I Will try with LACP
Before I was using a Cisco 3570 Trunking port on 1 & 2 to the both core switches port 20
enable sharing 1:1 grouping 1:1 - 4:1 algorithm port-based lacp
11-05-2020 02:36 PM
Hello Peternoclue:
Please check out the following commmand
enable sharing port grouping port_list {algorithm [address-based {L2 | L3 | L3_L4 | custom} | port-based }]} {resilient-hashing [on | off]}Thanks
Brad
11-05-2020 02:33 PM
Is the concern here that links are flapping that are part of LAG?
Is this LAG using LACP?
If so can you provide the output of “show lacp counters”?
Thanks,
Chris Thompson
