Maximum power consumption of 440-48p g2 vs 450-48p g2 Typo?
David_Rahn
Looking at the spec sheets for x440 g2 and x450 g2 and the sheet lists a max power usage of a 440-48p g2 10ge as 961watts,
a similar equipped x450 is listed as 228 watts.
Can anyone from Extreme verify how the x440 spec sheet is figured? or if one of them is a Typo?
http://learn.extremenetworks.com/rs/641-VMV-602/images/ExtremeSwitching-X440-G2-DS.pdf
http://learn.extremenetworks.com/rs/641-VMV-602/images/Summit-X450-G2-DS.pdf%20
thanks
Dave
8 REPLIES 8
Drew_C
Valued Contributor III
I wanted to update the discussion here to note that Engineering will be testing and will provide both values for the datasheets eventually. Unfortunately, I do not have an ETA from engineering as to when that will be done.
EtherMAN
Contributor III
They do read and they will jump in I am sure... I for sure see your point
Drew_C
Engineering has been asked to review the numbers in the datasheet since there seems to be a discrepancy in what the values listed actually indicate. Product Management should be back to comment.
Drew_C
I've forwarded a link to this thread to someone who I believe can help. We'll see what he comes back with.
