MLAG+VRRP is not works properly
Lexus92008
Hello, community!
I have some trouble in work two X690 like core switches, First is HQ-690, second is TR-690.
They are MLAG-peers, VRRP-peers.
We have VLAN 100, HQ-690 has ip 192.168.100.253, TR-690 has ip 192.168.100.252, VIP is 192.168.100.254.
MLAG VLAN has tag 2000, HQ-690 has ip 172.16.0.1/30, TR-690 has ip 172.16.0.2/30.
Then the problem:
When I connecting to HQ-690 via 192.168.100.253 through telnet, it has greate delays for inputed commands or close connection at all.
When I connecting to TR-690 via 192.168.100.252 through telnet, it has no delays. Then I connecting from TR-690 to HQ-690 via 172.16.0.1. It has no delays too.
Another devices in VLAN 100 has the same delays in work.
Both switches has the same EXOS 22.4.1.4 patch1-2
Config of HQ-690:
Module vrrp configuration. # create vrrp vlan VLAN_0099 vrid 100 configure vrrp vlan VLAN_0099 vrid 100 priority 200 create vrrp vlan VLAN_0095 vrid 100 configure vrrp vlan VLAN_0095 vrid 100 priority 200 create vrrp vlan VLAN_0100 vrid 100 configure vrrp vlan VLAN_0100 vrid 100 priority 200 create vrrp vlan VLAN_0101 vrid 100 configure vrrp vlan VLAN_0101 vrid 100 priority 200 create vrrp vlan VLAN_0103 vrid 100 configure vrrp vlan VLAN_0103 vrid 100 priority 200 create vrrp vlan VLAN_0105 vrid 100 configure vrrp vlan VLAN_0105 vrid 100 priority 200 create vrrp vlan VLAN_0106 vrid 100 configure vrrp vlan VLAN_0106 vrid 100 priority 200 create vrrp vlan VLAN_0210 vrid 100 configure vrrp vlan VLAN_0210 vrid 100 priority 200 create vrrp vlan VLAN_0114 vrid 100 configure vrrp vlan VLAN_0114 vrid 100 priority 200 configure vrrp vlan VLAN_0099 vrid 100 add 192.168.99.254 configure vrrp vlan VLAN_0095 vrid 100 add 192.168.95.254 configure vrrp vlan VLAN_0100 vrid 100 add 192.168.100.254 configure vrrp vlan VLAN_0101 vrid 100 add 192.168.102.254 configure vrrp vlan VLAN_0101 vrid 100 add 192.168.101.254 configure vrrp vlan VLAN_0103 vrid 100 add 192.168.104.254 configure vrrp vlan VLAN_0103 vrid 100 add 192.168.103.254 configure vrrp vlan VLAN_0105 vrid 100 add 192.168.105.254 configure vrrp vlan VLAN_0106 vrid 100 add 192.168.106.254 configure vrrp vlan VLAN_0210 vrid 100 add 192.168.210.254 configure vrrp vlan VLAN_0114 vrid 100 add 192.168.114.254 enable vrrp vlan VLAN_0099 vrid 100 enable vrrp vlan VLAN_0095 vrid 100 enable vrrp vlan VLAN_0100 vrid 100 enable vrrp vlan VLAN_0101 vrid 100 enable vrrp vlan VLAN_0103 vrid 100 enable vrrp vlan VLAN_0105 vrid 100 enable vrrp vlan VLAN_0106 vrid 100 enable vrrp vlan VLAN_0210 vrid 100 enable vrrp vlan VLAN_0114 vrid 100
# # Module vsm configuration. # create mlag peer "TR-690" configure mlag peer "TR-690" ipaddress 172.16.0.2 vr VR-Default enable mlag port 11 peer "TR-690" id 6 enable mlag port 12 peer "TR-690" id 7 enable mlag port 22 peer "TR-690" id 2 enable mlag port 23 peer "TR-690" id 5 enable mlag port 31 peer "TR-690" id 1 enable mlag port 47 peer "TR-690" id 4 enable mlag port 48 peer "TR-690" id 3 Conf of TR-690:
# # Module vrrp configuration. # create vrrp vlan VLAN_0099 vrid 100 create vrrp vlan VLAN_0095 vrid 100 create vrrp vlan VLAN_0100 vrid 100 create vrrp vlan VLAN_0101 vrid 100 create vrrp vlan VLAN_0103 vrid 100 create vrrp vlan VLAN_0105 vrid 100 create vrrp vlan VLAN_0106 vrid 100 create vrrp vlan VLAN_0210 vrid 100 create vrrp vlan VLAN_0114 vrid 100 configure vrrp vlan VLAN_0099 vrid 100 add 192.168.99.254 configure vrrp vlan VLAN_0095 vrid 100 add 192.168.95.254 configure vrrp vlan VLAN_0100 vrid 100 add 192.168.100.254 configure vrrp vlan VLAN_0101 vrid 100 add 192.168.102.254 configure vrrp vlan VLAN_0101 vrid 100 add 192.168.101.254 configure vrrp vlan VLAN_0103 vrid 100 add 192.168.104.254 configure vrrp vlan VLAN_0103 vrid 100 add 192.168.103.254 configure vrrp vlan VLAN_0105 vrid 100 add 192.168.105.254 configure vrrp vlan VLAN_0106 vrid 100 add 192.168.106.254 configure vrrp vlan VLAN_0210 vrid 100 add 192.168.210.254 configure vrrp vlan VLAN_0114 vrid 100 add 192.168.114.254 enable vrrp vlan VLAN_0099 vrid 100 enable vrrp vlan VLAN_0095 vrid 100 enable vrrp vlan VLAN_0100 vrid 100 enable vrrp vlan VLAN_0101 vrid 100 enable vrrp vlan VLAN_0103 vrid 100 enable vrrp vlan VLAN_0105 vrid 100 enable vrrp vlan VLAN_0106 vrid 100 enable vrrp vlan VLAN_0210 vrid 100 enable vrrp vlan VLAN_0114 vrid 100 # # Module vsm configuration. # create mlag peer "HQ-690" configure mlag peer "HQ-690" ipaddress 172.16.0.1 vr VR-Default enable mlag port 11 peer "HQ-690" id 6 enable mlag port 12 peer "HQ-690" id 7 enable mlag port 22 peer "HQ-690" id 2 enable mlag port 23 peer "HQ-690" id 5 enable mlag port 31 peer "HQ-690" id 1 enable mlag port 47 peer "HQ-690" id 4 enable mlag port 48 peer "HQ-690" id 3
17 REPLIES 17
Turned on LACP on HP's and enabled sharing on extreme's.
No changes...
Lexus92008
As I know, if on first side lacp is enabled, but on second is not, trafic will not be transmitted at all.
Here we can see packet delays and losses, but it works.
All this switches are in production, so we can't change anything that can cause service to stop.
Frank
Contributor II
Thanks!
Now, on the 690s, do you have an entry like "enable sharing port 22 grouping 22" (assuming that port 22 is the uplink port to the HP switch(es) ?
You may need to do something like
- enable sharing 22 grouping 22 lacp
and maybe even (I had to do that for our attached Ciscos, as they don't negotiate priorities well):
- configure sharing 22 lacp system-priority 32768
But I'd first try without that line.
Lexus92008
HP-5130 configuration:
<1159/1160_HP-5130-24G-SFP_HQ-R132-S1-U35/36>show current-configuration # version 7.1.070, Release 3208P03 # sysname 1159/1160_HP-5130-24G-SFP_HQ-R132-S1-U35/36 # clock timezone Ekaterinburg add 05:00:00 clock protocol ntp # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 32 irf member 2 priority 1 # ip unreachables enable ip ttl-expires enable # dhcp snooping enable # password-recovery enable # vlan 1 # vlan 95 description LSY # vlan 100 name Control description Control # vlan 101 description net_101 # vlan 102 description net_102 # vlan 106 description net_106 # vlan 111 description Control_Wi-Fi # vlan 154 description Wi-Fi_VIP # vlan 210 description net_210 # vlan 250 description Wi-Fi_Guest # vlan 500 description border_to_dhcp # vlan 3102 # irf-port 1/1 port group interface Ten-GigabitEthernet1/0/25 port group interface Ten-GigabitEthernet1/0/26 # irf-port 2/2 port group interface Ten-GigabitEthernet2/0/27 port group interface Ten-GigabitEthernet2/0/28 # stp global enable # interface Bridge-Aggregation1 description LAG_to_Extreme port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 undo stp enable dhcp snooping trust # interface Bridge-Aggregation2 description LAG_to_1209 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 undo stp enable dhcp snooping trust # interface Bridge-Aggregation3 description LAG_to_1210 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 undo stp enable # interface Bridge-Aggregation4 description LAG_to_1208 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 undo stp enable # interface Bridge-Aggregation5 description LAG_to_1211 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 undo stp enable # interface Bridge-Aggregation6 description LAG_to_1201 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 undo stp enable # interface Bridge-Aggregation7 description LAG_to_1236 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 undo stp enable # interface Bridge-Aggregation8 description LAG_to_1199_HQ-k219 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 undo stp enable # interface NULL0 # interface Vlan-interface100 ip address 192.168.100.65 255.255.255.0 # interface GigabitEthernet1/0/1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 port link-aggregation group 2 # interface GigabitEthernet1/0/2 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 3 # interface GigabitEthernet1/0/3 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 4 # interface GigabitEthernet1/0/4 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 5 # interface GigabitEthernet1/0/5 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 6 # interface GigabitEthernet1/0/6 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 port link-aggregation group 7 # interface GigabitEthernet1/0/7 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 # interface GigabitEthernet1/0/8 # interface GigabitEthernet1/0/9 # interface GigabitEthernet1/0/10 # interface GigabitEthernet1/0/11 # interface GigabitEthernet1/0/12 # interface GigabitEthernet1/0/13 # Š”ŠµŃ€Š³ŠµŠ¹ Š—ŠµŠ¼Š»ŃŠ½ŃŠŗŠøŠ¹, [26.06.18 13:26] interface GigabitEthernet1/0/14 # interface GigabitEthernet1/0/15 # interface GigabitEthernet1/0/16 # interface GigabitEthernet1/0/17 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 combo enable copper port link-aggregation group 8 # interface GigabitEthernet1/0/18 port access vlan 100 combo enable copper # interface GigabitEthernet1/0/19 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 91 99 to 101 111 154 250 combo enable copper # interface GigabitEthernet1/0/20 combo enable copper # interface GigabitEthernet1/0/21 combo enable copper # interface GigabitEthernet1/0/22 combo enable copper # interface GigabitEthernet1/0/23 combo enable copper # interface GigabitEthernet1/0/24 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 combo enable fiber # interface GigabitEthernet2/0/1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 port link-aggregation group 2 # interface GigabitEthernet2/0/2 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 3 # interface GigabitEthernet2/0/3 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 4 # interface GigabitEthernet2/0/4 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 5 # interface GigabitEthernet2/0/5 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 106 111 154 210 250 254 port link-aggregation group 6 # interface GigabitEthernet2/0/6 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 port link-aggregation group 7 # interface GigabitEthernet2/0/7 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 # interface GigabitEthernet2/0/8 # interface GigabitEthernet2/0/9 # interface GigabitEthernet2/0/10 # interface GigabitEthernet2/0/11 # interface GigabitEthernet2/0/12 # interface GigabitEthernet2/0/13 # interface GigabitEthernet2/0/14 # interface GigabitEthernet2/0/15 # interface GigabitEthernet2/0/16 # interface GigabitEthernet2/0/17 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 to 101 combo enable copper port link-aggregation group 8 # interface GigabitEthernet2/0/18 combo enable copper # interface GigabitEthernet2/0/19 combo enable copper # interface GigabitEthernet2/0/20 combo enable copper # interface GigabitEthernet2/0/21 combo enable copper # interface GigabitEthernet2/0/22 combo enable copper # interface GigabitEthernet2/0/23 combo enable copper # interface GigabitEthernet2/0/24 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 100 combo enable fiber # interface Ten-GigabitEthernet1/0/27 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 speed 1000 port link-aggregation group 1 # interface Ten-GigabitEthernet1/0/28 # interface Ten-GigabitEthernet2/0/25 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 95 100 to 101 106 111 154 210 250 500 3101 to 3102 speed 1000 port link-aggregation group 1 # interface Ten-GigabitEthernet2/0/26 # interface Ten-GigabitEthernet1/0/25 # interface Ten-GigabitEthernet1/0/26 # interface Ten-GigabitEthernet2/0/27 # interface Ten-GigabitEthernet2/0/28 # scheduler logfile size 16 # line class aux user-role network-admin # line class vty user-role network-operator # line aux 0 1 user-role network-admin # line vty 0 15 authentication-mode scheme user-role network-admin user-role network-operator protocol inbound ssh idle-timeout 0 0 # line vty 16 authentication-mode scheme user-role network-admin user-role network-operator protocol inbound telnet idle-timeout 0 0 # line vty 17 63 Š”ŠµŃ€Š³ŠµŠ¹ Š—ŠµŠ¼Š»ŃŠ½ŃŠŗŠøŠ¹, [26.06.18 13:26] authentication-mode scheme user-role network-admin user-role network-operator protocol inbound telnet # ip route-static 192.168.100.0 24 192.168.100.254 ip route-static 192.168.210.0 24 192.168.100.254 # snmp-agent snmp-agent local-engineid 800063A2802C233A3C7FBF00000001 snmp-agent community read public snmp-agent sys-info contact ost@u6.ru snmp-agent sys-info location HQ-R132-S1-U36/35 snmp-agent sys-info version all # ssh server enable # ntp-service enable ntp-service unicast-server 192.168.210.222 # radius scheme system user-name-format without-domain # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$tlm9B/4vbo80MImC$v1MiGwbgkmHLCKZeAyjScgwvmGqpATJ168y/tN0CyMNXzRGtmRue3e/Uv02lhe6Gnti8bPVRlwMA/9kLFZEs4w== service-type telnet http https pad ssh terminal authorization-attribute user-role network-admin authorization-attribute user-role network-operator # local-user backup class manage password hash $h$6$awUXBjDKKcqvVYuy$RXh/xeGaZEEiKkhFaMX+GoLBMSnEpmhnlwkOtzwuhifIvkFlofrh2lL8oS/d5jz7n6donUxpRp95xgRPNsehAA== service-type telnet ssh authorization-attribute user-role network-admin authorization-attribute user-role network-operator # ip http enable ip https enable # return
Lexus92008
My workstation is on TP-Link switch.
Port configuration on HQ-690:
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-72 configure vr VR-Default add ports 1-72 configure vlan default delete ports 1-72 configure vlan untagged-ports auto-move off create qosprofile "QP2" create qosprofile "QP3" create qosprofile "QP4" create vlan "border_to_junuser" configure vlan border_to_junuser tag 20 create vlan "CIC" configure vlan CIC tag 1093 create vlan "control_eaps1" configure vlan control_eaps1 tag 1090 create vlan "LifeMigration" configure vlan LifeMigration tag 1091 create vlan "MLAG_CONTROL" configure vlan MLAG_CONTROL tag 2000 create vlan "SMB" configure vlan SMB tag 1092 create vlan "VLAN_0091" configure vlan VLAN_0091 tag 91 create vlan "VLAN_0095" configure vlan VLAN_0095 description "LuftGansa Systems Vlan" configure vlan VLAN_0095 tag 95 create vlan "VLAN_0098" configure vlan VLAN_0098 description "backup" configure vlan VLAN_0098 tag 98 create vlan "VLAN_0099" configure vlan VLAN_0099 tag 99 create vlan "VLAN_0100" configure vlan VLAN_0100 tag 100 create vlan "VLAN_0101" configure vlan VLAN_0101 description "HQ_101_102-SubNet" configure vlan VLAN_0101 tag 101 create vlan "VLAN_0103" configure vlan VLAN_0103 tag 103 create vlan "VLAN_0105" configure vlan VLAN_0105 tag 105 create vlan "VLAN_0106" configure vlan VLAN_0106 description "Block B" configure vlan VLAN_0106 tag 106 create vlan "VLAN_0107" configure vlan VLAN_0107 tag 107 create vlan "VLAN_0111" configure vlan VLAN_0111 description "Management Vlan Wi-Fi" configure vlan VLAN_0111 tag 111 create vlan "VLAN_0112" configure vlan VLAN_0112 tag 112 create vlan "VLAN_0114" configure vlan VLAN_0114 tag 114 create vlan "VLAN_0154" configure vlan VLAN_0154 description "Wi-Fi_net_U6" configure vlan VLAN_0154 tag 154 create vlan "VLAN_0210" configure vlan VLAN_0210 tag 210 create vlan "VLAN_0250" configure vlan VLAN_0250 tag 250 create vlan "VLAN_0254" configure vlan VLAN_0254 tag 254 configure ports 1 auto on speed 1000 configure ports 2 auto on speed 1000 configure ports 3 auto on speed 1000 configure ports 4 auto on speed 1000 configure ports 5 auto on speed 1000 configure ports 6 auto on speed 1000 configure ports 7 auto on speed 1000 configure ports 8 auto on speed 1000 configure ports 9 auto on speed 1000 configure ports 10 auto on speed 1000 configure ports 11 auto off speed 1000 duplex full configure ports 12 auto off speed 1000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 10000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto on speed 1000 configure ports 18 auto off speed 10000 duplex full configure ports 19 auto on speed 1000 configure ports 20 auto off speed 1000 duplex full configure ports 21 auto off speed 1000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 25 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full configure ports 29 auto off speed 10000 duplex full configure ports 30 auto off speed 10000 duplex full configure ports 31 auto off speed 1000 duplex full configure ports 32 auto off speed 1000 duplex full configure ports 33 auto off speed 10000 duplex full configure ports 34 auto off speed 10000 duplex full configure ports 35 auto off speed 10000 duplex full configure ports 36 auto off speed 10000 duplex full configure ports 37 auto off speed 10000 duplex full configure ports 38 auto off speed 10000 duplex full configure ports 39 auto off speed 10000 duplex full configure ports 40 auto off speed 10000 duplex full configure ports 41 auto off speed 10000 duplex full configure ports 42 auto off speed 10000 duplex full configure ports 43 auto off speed 10000 duplex full configure ports 44 auto off speed 10000 duplex full configure ports 45 auto off speed 10000 duplex full configure ports 46 auto off speed 10000 duplex full configure ports 47 auto off speed 10000 duplex full configure ports 48 auto off speed 10000 duplex full configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full configure ports 54 auto off speed 10000 duplex full configure ports 55 auto off speed 10000 duplex full configure ports 56 auto off speed 10000 duplex full enable flow-control rx-pause qosprofile qp4 port 61 enable flow-control tx-pause priority 3 port 61 enable flow-control rx-pause qosprofile qp4 port 65 enable flow-control tx-pause priority 3 port 65 enable flow-control rx-pause qosprofile qp4 port 69 enable flow-control tx-pause priority 3 port 69 configure vlan CIC add ports 61,65,69 tagged configure vlan control_eaps1 add ports 61,69 tagged configure vlan LifeMigration add ports 61,65,69 tagged configure vlan MLAG_CONTROL add ports 69 tagged configure vlan SMB add ports 61,65,69 tagged configure vlan VLAN_0091 add ports 1-3,7,11-12,14,17,20,47-48,69 tagged configure vlan VLAN_0095 add ports 1-3,5,7,11-12,14,16-17,69 tagged configure vlan VLAN_0098 add ports 1,3,11-12,69 tagged configure vlan VLAN_0099 add ports 1-3,7,11-12,14,17,47-48,69 tagged configure vlan VLAN_0100 add ports 1-3,6-7,10-12,17,20-23,31,69 tagged configure vlan VLAN_0101 add ports 17,22,69 tagged configure vlan VLAN_0103 add ports 10,23,69 tagged configure vlan VLAN_0105 add ports 10,69 tagged configure vlan VLAN_0106 add ports 6,17,22,69 tagged configure vlan VLAN_0107 add ports 7,69 tagged configure vlan VLAN_0111 add ports 1,3,6-7,10,17,20,22-23,69 tagged configure vlan VLAN_0112 add ports 7,69 tagged configure vlan VLAN_0112 add ports 8 untagged configure vlan VLAN_0114 add ports 69 tagged configure vlan VLAN_0114 add ports 13 untagged configure vlan VLAN_0154 add ports 6-7,10,17,20,23,69 tagged configure vlan VLAN_0210 add ports 1-3,7,10-12,14,17,22,69 tagged configure vlan VLAN_0210 add ports 4-5,9,20 untagged configure vlan VLAN_0250 add ports 1,6-7,10,17,20,22-23,69 tagged configure vlan VLAN_0254 add ports 1-2,6-7,17,20,69 tagged configure vlan Mgmt ipaddress 192.168.100.253 255.255.255.0 configure vlan VLAN_0099 ipaddress 192.168.99.253 255.255.255.0 enable ipforwarding vlan VLAN_0099 configure vlan border_to_junuser ipaddress 10.130.1.10 255.255.255.252 enable ipforwarding vlan border_to_junuser configure vlan VLAN_0095 ipaddress 192.168.95.253 255.255.255.0 enable ipforwarding vlan VLAN_0095 configure vlan VLAN_0100 ipaddress 192.168.100.253 255.255.255.0 enable ipforwarding vlan VLAN_0100 configure vlan VLAN_0101 ipaddress 192.168.101.253 255.255.255.0 enable ipforwarding vlan VLAN_0101 configure vlan VLAN_0101 add secondary-ipaddress 192.168.102.253 255.255.255.0 configure vlan VLAN_0103 ipaddress 192.168.103.253 255.255.255.0 enable ipforwarding vlan VLAN_0103 configure vlan VLAN_0103 add secondary-ipaddress 192.168.104.253 255.255.255.0 configure vlan VLAN_0105 ipaddress 192.168.105.253 255.255.255.0 enable ipforwarding vlan VLAN_0105 configure vlan VLAN_0106 ipaddress 192.168.106.253 255.255.255.0 enable ipforwarding vlan VLAN_0106 configure vlan VLAN_0210 ipaddress 192.168.210.253 255.255.255.0 enable ipforwarding vlan VLAN_0210 configure vlan MLAG_CONTROL ipaddress 172.16.0.1 255.255.255.252 configure vlan VLAN_0114 ipaddress 192.168.114.253 255.255.255.0 enable ipforwarding vlan VLAN_0114Port configuration on TR-690:
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-72 configure vr VR-Default add ports 1-72 configure vlan default delete ports 1-72 configure vlan untagged-ports auto-move off create qosprofile "QP2" create qosprofile "QP3" create qosprofile "QP4" create vlan "CIC" configure vlan CIC tag 1093 create vlan "control_eaps1" configure vlan control_eaps1 tag 1090 create vlan "LifeMigration" configure vlan LifeMigration tag 1091 create vlan "MLAG_CONTROL" configure vlan MLAG_CONTROL tag 2000 create vlan "SMB" configure vlan SMB tag 1092 create vlan "VLAN_0091" configure vlan VLAN_0091 tag 91 create vlan "VLAN_0095" configure vlan VLAN_0095 tag 95 create vlan "VLAN_0098" configure vlan VLAN_0098 description "backup" configure vlan VLAN_0098 tag 98 create vlan "VLAN_0099" configure vlan VLAN_0099 tag 99 create vlan "VLAN_0100" configure vlan VLAN_0100 tag 100 create vlan "VLAN_0101" configure vlan VLAN_0101 tag 101 create vlan "VLAN_0103" configure vlan VLAN_0103 tag 103 create vlan "VLAN_0105" configure vlan VLAN_0105 tag 105 create vlan "VLAN_0106" configure vlan VLAN_0106 tag 106 create vlan "VLAN_0107" configure vlan VLAN_0107 tag 107 create vlan "VLAN_0111" configure vlan VLAN_0111 description "Management Vlan Wi-Fi" configure vlan VLAN_0111 tag 111 create vlan "VLAN_0112" configure vlan VLAN_0112 tag 112 create vlan "VLAN_0114" configure vlan VLAN_0114 tag 114 create vlan "VLAN_0154" configure vlan VLAN_0154 description "Wi-Fi_net_U6" configure vlan VLAN_0154 tag 154 create vlan "VLAN_0210" configure vlan VLAN_0210 tag 210 create vlan "VLAN_0250" configure vlan VLAN_0250 tag 250 create vlan "VLAN_0254" configure vlan VLAN_0254 tag 254 configure ports 1 auto off speed 10000 duplex full configure ports 2 auto off speed 10000 duplex full configure ports 3 auto off speed 10000 duplex full configure ports 4 auto off speed 10000 duplex full configure ports 5 auto off speed 10000 duplex full configure ports 6 auto off speed 10000 duplex full configure ports 7 auto off speed 10000 duplex full configure ports 8 auto off speed 10000 duplex full configure ports 9 auto off speed 10000 duplex full configure ports 10 auto off speed 10000 duplex full configure ports 11 auto off speed 10000 duplex full configure ports 12 auto off speed 10000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 1000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto off speed 10000 duplex full configure ports 18 auto off speed 10000 duplex full configure ports 19 auto off speed 10000 duplex full configure ports 20 auto off speed 10000 duplex full configure ports 21 auto off speed 10000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 25 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full configure ports 29 auto off speed 10000 duplex full configure ports 30 auto off speed 10000 duplex full configure ports 31 auto off speed 1000 duplex full configure ports 32 auto off speed 10000 duplex full configure ports 33 auto off speed 10000 duplex full configure ports 34 auto off speed 10000 duplex full configure ports 35 auto off speed 10000 duplex full configure ports 36 auto off speed 10000 duplex full configure ports 37 auto off speed 10000 duplex full configure ports 38 auto off speed 10000 duplex full configure ports 39 auto off speed 10000 duplex full configure ports 40 auto off speed 10000 duplex full configure ports 41 auto off speed 10000 duplex full configure ports 42 auto off speed 10000 duplex full configure ports 43 auto off speed 10000 duplex full configure ports 44 auto off speed 10000 duplex full configure ports 45 auto off speed 10000 duplex full configure ports 46 auto off speed 10000 duplex full configure ports 47 auto off speed 10000 duplex full configure ports 48 auto off speed 10000 duplex full configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full configure ports 54 auto off speed 10000 duplex full configure ports 55 auto off speed 10000 duplex full configure ports 56 auto off speed 10000 duplex full enable flow-control rx-pause qosprofile qp4 port 61 enable flow-control tx-pause priority 3 port 61 enable flow-control rx-pause qosprofile qp4 port 65 enable flow-control tx-pause priority 3 port 65 enable flow-control rx-pause qosprofile qp4 port 69 enable flow-control tx-pause priority 3 port 69 configure vlan CIC add ports 61,65,69 tagged configure vlan control_eaps1 add ports 61,69 tagged configure vlan LifeMigration add ports 61,65,69 tagged configure vlan MLAG_CONTROL add ports 69 tagged configure vlan SMB add ports 61,65,69 tagged configure vlan VLAN_0091 add ports 11-12,14,47-48,61,69 tagged configure vlan VLAN_0095 add ports 11-12,14,69 tagged configure vlan VLAN_0098 add ports 11-12,69 tagged configure vlan VLAN_0099 add ports 11-12,14,47-48,61,69 tagged configure vlan VLAN_0100 add ports 11-12,22-23,31,69 tagged configure vlan VLAN_0101 add ports 22,69 tagged configure vlan VLAN_0103 add ports 23,69 tagged configure vlan VLAN_0105 add ports 69 tagged configure vlan VLAN_0106 add ports 22,69 tagged configure vlan VLAN_0107 add ports 69 tagged configure vlan VLAN_0111 add ports 22-23,69 tagged configure vlan VLAN_0112 add ports 69 tagged configure vlan VLAN_0114 add ports 69 tagged configure vlan VLAN_0114 add ports 5 untagged configure vlan VLAN_0154 add ports 23,69 tagged configure vlan VLAN_0210 add ports 11-12,14,22,69 tagged configure vlan VLAN_0250 add ports 22-23,69 tagged configure vlan VLAN_0254 add ports 69 tagged configure vlan Mgmt ipaddress 192.168.100.252 255.255.255.0 configure vlan VLAN_0099 ipaddress 192.168.99.252 255.255.255.0 enable ipforwarding vlan VLAN_0099 configure vlan MLAG_CONTROL ipaddress 172.16.0.2 255.255.255.252 configure vlan VLAN_0095 ipaddress 192.168.95.252 255.255.255.0 enable ipforwarding vlan VLAN_0095 configure vlan VLAN_0100 ipaddress 192.168.100.252 255.255.255.0 enable ipforwarding vlan VLAN_0100 configure vlan VLAN_0101 ipaddress 192.168.101.252 255.255.255.0 enable ipforwarding vlan VLAN_0101 configure vlan VLAN_0101 add secondary-ipaddress 192.168.102.252 255.255.255.0 configure vlan VLAN_0103 ipaddress 192.168.103.252 255.255.255.0 enable ipforwarding vlan VLAN_0103 configure vlan VLAN_0103 add secondary-ipaddress 192.168.104.252 255.255.255.0 configure vlan VLAN_0105 ipaddress 192.168.105.252 255.255.255.0 enable ipforwarding vlan VLAN_0105 configure vlan VLAN_0106 ipaddress 192.168.106.252 255.255.255.0 enable ipforwarding vlan VLAN_0106 configure vlan VLAN_0210 ipaddress 192.168.210.252 255.255.255.0 enable ipforwarding vlan VLAN_0210 configure vlan VLAN_0254 ipaddress 192.168.254.242 255.255.255.0 enable ipforwarding vlan VLAN_0254 configure vlan VLAN_0114 ipaddress 192.168.114.252 255.255.255.0 enable ipforwarding vlan VLAN_0114
