Multicast routing between VRF's
mael
Hi!
I wondering if it's possible to route incoming multicast from one VR to another VR in the same machine?
The reason is that I want to isolate a PIM domain for our IPTV customers from our core network. A simple solution would be to do a loop in the switch and push all traffic over that link, but that's cheating 😉
Would be thankful for some insight and maybe configuration samples.
With regards
Mattias
10 REPLIES 10
Julian_Eble
New Contributor II
Well I would like to have same thing with our network.
The main core runs with MPLS but the PIM are doing the same work in the same OSPF area..
I would like to create VR's and run the multicast separately.
Michael_Suggs1
New Contributor II
Not trying to high jack this post, but have a similar issue. i have a 460 with pim sparse to a external RP off my network. i pull 324 multicast via this sparse vlan. the rest of my network is currently dense, working as it is , i want to convert my entire network from dense to all sparse. which will cause me to have a different RP on my own network. could i use this same inter-VR solution to pass multicast from my current sparse VR to a new separate VR sparse ring? i was kind of thinking of using MSDP. thanks in advance,
Mike_D
Hey Mattias
I understand the business requirement but even unicast route leaking is a non-trivial task. Inter-vrf routing has always confused me. Take
My rule of thumb for multicast: the simplest solution that solves the problem is generally the right solution. PIM troubleshooting causes heartburn for many a network admin.
I am glad there's a workaround in this case - that always makes the conversation easier. And I'm always happy to see folks coming to the HUB community with these sorts of questions. It's a time saver and maybe saves you a call to support. And of course we welcome the discussion. Ultimately its customer requirements that decide direction - so we need to hear it.
I'm not saying its hip or elegant, but life is much easier with a five inch cat5 cable handling the tricky business.
Best regards,
Mike
Henrique
Hi Mattias,
You can find more details about the information provided by Stephen in the article below:
Routing configuration between VRs
