Ping to the internet from virtual exos doesn't work
Ala_Eddine_Chhi
I am new user of Extreme products, so i installed EXOS for virtual lab but when i did all the configuration (vlan, ipaddress, port) , i couldn't ping any website or server in the internet , i can't even ping my default gateway .So, can someone help me to resolve this problem?
Thank you
28 REPLIES 28
d0d35bec7b834b27946208f91af73772_RackMultipart20160628-118164-15aiev8-Untitled_inline.png
here the result of sh vlan
Henrique
Hi Ala,
Could you please try configuring your Adapter 2 instead of Adapter 1? I guess that your adapter 1 might be representing the EXOS Mgmt port.
Also, please share the output below:
show vlan
i did it
c97c958b1d994d14bf494b1eb1a535ce_RackMultipart20160628-119104-1cp5un6-Untitled_inline.png
BrandonC
What hypervisor are you running this VM in? What does the virtual network config look like in the hypervisor?
Is the virtual network with 192.168.1.254 on it attached to port 1 on the VM?
Also, if you have Wireshark installed, can you try taking a packet capture on your PCs adapter that's connected to the virtual network? This way we can see if the traffic is leaving the VM and hitting the vSwitch. (This is assuming that your PC is 192.168.1.254)
-Brandon
The first adapter in VirtualBox is the management port of the EXOS VM. The "front panel" ports of the VM are the VirtualBox adapters starting at 2.
