POE issues switches, suddently POE is going dead, we need to do manualy "disable & enable inline-power slot " for it work
Avinash_Paul2
POE issues in x440, x460 switches, suddently POE is going dead, we need to do manualy "disable inline-power slot " and "enable inline-power slot " for it work
1 REPLY 1
Karthik_Mohando
Hi Avinash,
Can you share the logs taken during the failure is any?
"show log" and "show log messages nvram"
Also what is the EXOS version running in the switch? "show switch", "show version" and "show stacking"
Does this happen only after a slot/switch reboot or during normal operations?
