Port Load sharing
Port Load sharing
Paul11
Contributor
After i enable Lacp .. port is not sharing. Utilization is high on Link 1 only.
I want to use load balance on both links.
Please kindly see the below output and advice thanks.
* I try L2 static, L3_L4 and LACP. all the same ports are not load balance. *
enable sharing 1 grouping 1,4
enable sharing 1 grouping 1,4 L3_L4
enable sharing 1 grouping 1,4 algorithm address-based L3_L4 lacp
CoreSW # sh port 1,4 utilization bandwithPort Link Link Rx Peak Rx Tx Peak Tx
State Speed % bandwidth % bandwidth % bandwidth % bandwidth
Link_1> A 1000 82.06 94.94 48.23 55.72
Link_2> A 1000 0.25 0.30 1.34 1.57
> indicates Port Display Name truncated past 8 characters
Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
CoreSW #sh sharing
Load Sharing Monitor
Config Current Agg Ld Share Ld Share Agg Link Link Up
Master Master Control Algorithm Group Mbr State Transitions
1 1 LACP L3_L4 1 Y A 0
L3_L4 4 Y A 0
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Load Sharing Algorithm: (L2) Layer 2 address based
(L3_L4) Layer 3 address and Layer 4 port based
Number of load sharing trunks: 1
Core2 # sh lacp lag 1
Lag Actor Actor Partner Partner Partner Agg Actor
Sys-Pri Key MAC Sys-Pri Key Count MAC
1 0 0x03e9 00:04:96:34:b2:e1 0 0x03e9 2 00:04:96:34:b2:e0
Port list:
Member Port Rx Sel Mux Actor Partner
Port Priority State Logic State Flags Port
1 0 Current Selected Collect-Dist A-GSCD-- 1001
4 0 Current Selected Collect-Dist A-GSCD-- 1012
Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization
C-Collecting, D-Distributing, F-Defaulted, E-Expired
43 REPLIES 43
Yes i did sharing on both switches. Thanks.
Please kindly share the show command of
show port 21-24 utilization bandwidth
Is it load balance on port 21-24 links?
could you please share the outcome of
sh port 21,24 utilization bandwith
Jarek
New Contributor II
I have two X250e with config like bellow:
"enable sharing 24 grouping 21-24 algorithm address-based L3_L4"
and all is working well (EXOS ver 15.3.1.4-1-30).
Did you enabled sharing on both swicthes?
Thanks Jarek,
Core1 and Core 2 using X450a-24x
LACP is between two Core Switches.
ExtremeXOS version 15.3.1.4
Please advice thanks.
We want to use load balance on both links.
