Power Usage exceeded and cleared logs on X430-8P Switch
Saiprasad_Rao_R
New Contributor II
I an seeing the below logs continuously, is it a serious issue, what has to be done......
ff33858a32da443fb21aa7f01b5d8ade_RackMultipart20150902-18797-10x6jgp-power_usage_inline.jpg
6 REPLIES 6
Sorry, based on the logs I thought it was a stack. However, it looks like the log will show 'slot 1' for a standalone switch as well.
The reason that this does not occur on the X440 is that the X440 has a larger power budget for PoE. The X440-8p supports up to 170W, and the 24 and 48 port versions have a maximum of 380W.
Since this is a standalone X430-8p, there is an option to increase the PoE budget, up to 90W.
Note that since this switch relies on passive cooling, it may overheat if this configuration change is made and airflow around the switch is not sufficient.
The command to do this is below.
configure inline-power budget 90 -Brandon
Its not a stack , its a single device...... if i use x440p replacing 430p then no logs at all regarding the power exceedence. what if i ignore the logs, will it cause any issues..... right now power usage threshold is 70 , can i set it to 80.... is that OK.
