A simple ring of EAPS is configured in x440 switches, of which the primary and secondary links of each switches in transit mode and master are members of a static LAG. The problem occurs when you try to close the EAPS on the Master switch, a latency is generated that only affects the Master switches. It was verified that there are packages dropped from the ports in LAG when closing the EAPS. I attach the configuration and the logs:
# Module eaps configuration.
enable eaps
create eaps EAPS-INCHCAPE
configure eaps EAPS-INCHCAPE mode master
configure eaps EAPS-INCHCAPE primary port 1:1
configure eaps EAPS-INCHCAPE secondary port 1:48
enable eaps EAPS-INCHCAPE
configure eaps EAPS-INCHCAPE add protected vlan V20
configure eaps EAPS-INCHCAPE add protected vlan V80
configure eaps EAPS-INCHCAPE add protected vlan v10
configure eaps EAPS-INCHCAPE add protected vlan v11
configure eaps EAPS-INCHCAPE add protected vlan v12
configure eaps EAPS-INCHCAPE add protected vlan v21
configure eaps EAPS-INCHCAPE add protected vlan v50
configure eaps EAPS-INCHCAPE add protected vlan v100
configure eaps EAPS-INCHCAPE add control vlan EAPS-CONTROL
Slot-1 SWMOFYC1.32 # sho ports 1:1,1:48 vlan
Untagged
Port /Tagged VLAN Name(s)
1:1 Untagged None
Tagged EAPS-CONTROL, V20, V80, v10, v100, v11, v12, v21, v50
Enl-Edf.B
Untagged None
Slot-1 SWMOFYC1.33 #
enable sharing 1:48 grouping 1:48,2:48 algorithm address-based L2
enable sharing 1:1 grouping 1:1,1:4 algorithm address-based L2
