Problem EAPS with LAG:
‎06-19-2018 01:38 PM
A simple ring of EAPS is configured in x440 switches, of which the primary and secondary links of each switches in transit mode and master are members of a static LAG. The problem occurs when you try to close the EAPS on the Master switch, a latency is generated that only affects the Master switches. It was verified that there are packages dropped from the ports in LAG when closing the EAPS. I attach the configuration and the logs:
# Module eaps configuration.
enable eaps
create eaps EAPS-INCHCAPE
configure eaps EAPS-INCHCAPE mode master
configure eaps EAPS-INCHCAPE primary port 1:1
configure eaps EAPS-INCHCAPE secondary port 1:48
enable eaps EAPS-INCHCAPE
configure eaps EAPS-INCHCAPE add protected vlan V20
configure eaps EAPS-INCHCAPE add protected vlan V80
configure eaps EAPS-INCHCAPE add protected vlan v10
configure eaps EAPS-INCHCAPE add protected vlan v11
configure eaps EAPS-INCHCAPE add protected vlan v12
configure eaps EAPS-INCHCAPE add protected vlan v21
configure eaps EAPS-INCHCAPE add protected vlan v50
configure eaps EAPS-INCHCAPE add protected vlan v100
configure eaps EAPS-INCHCAPE add control vlan EAPS-CONTROL
Slot-1 SWMOFYC1.32 # sho ports 1:1,1:48 vlan
Untagged
Port /Tagged VLAN Name(s)
1:1 Untagged None
Tagged EAPS-CONTROL, V20, V80, v10, v100, v11, v12, v21, v50
Enl-Edf.B
Untagged None
Slot-1 SWMOFYC1.33 #
enable sharing 1:48 grouping 1:48,2:48 algorithm address-based L2
enable sharing 1:1 grouping 1:1,1:4 algorithm address-based L2
enable eaps
Untagged
1:1 Untagged None
Enl-Edf.B
Untagged None
3 REPLIES 3
‎06-23-2018 10:59 PM
The problem of latency is constant. Also I just made some modifications around the Master switch of the EAPS that has been changed. However I am presenting latency at the time of testing the link changes and when the EAPS is complete there is latency at times. Please your support.
Additionally the links of the link-aggregattion should be of L3_L4 lacp. Why do I currently have static and L2 configured?
‎06-20-2018 08:39 AM
Hi Kevin, Do you find a momentary lapse or is it continuously dropping packets? If the latency is temporary, looks like the sequence of events in creating the LAG and the EAPS ring matters. More in this article below -
https://gtacknowledge.extremenetworks.com/articles/Q_A/Creating-a-port-share-when-the-master-seconda...
‎06-20-2018 04:36 AM
Try to use lacp
I'm running this config with both address-based L2 lacp and address-based l3-l4 lacp
