Problem tag vlan between ap7522 and switch summit x450e-48p
‎05-21-2019 02:55 PM
hello,
In the goal to connect ap7522 to switch X450e . i have creat 1 Vlan "config" (tag 5) with ports 3 (untag) ,17(tagged) and 19(tagged) on the switch.
To setup ap7522. i've tag native vlan 5 and allowed this one . but this configuration don't run . But if i creat the same configuration on Vlan 1 "Default" this one running.
Thank you in advance for your answer. Thomas
code:
Configuration for vlan 1 on switch (this configuration run)
* X450e-48p.34 # sh vlan "Default"
VLAN Interface with name Default created by user
Admin State: Enabled Tagging: 802.1Q Tag 1
Description: None
Virtual router: VR-Default
IPv4 Forwarding: Disabled
IPv4 MC Forwarding: Disabled
IPv6 Forwarding: Disabled
IPv6 MC Forwarding: Disabled
IPv6: None
STPD: s0(Disabled,Auto-bind)
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
QosProfile: None configured
Egress Rate Limit Designated Port: None configured
Flood Rate Limit QosProfile: None configured
Ports: 2. (Number of active ports=3)
Untag: *3,
Tag: *17, *19
Flags: (*) Active, (!) Disabled, (g) Load Sharing port
(b) Port blocked on the vlan, (m) Mac-Based port
(a) Egress traffic allowed for NetLogin
(u) Egress traffic unallowed for NetLogin
(t) Translate VLAN tag for Private-VLAN
(s) Private-VLAN System Port, (L) Loopback port
(e) Private-VLAN End Point Port
(x) VMAN Tag Translated port
(G) Multi-switch LAG Group port
(H) Dynamically added by MVRP
(U) Dynamically added uplink port
(V) Dynamically added by VM Tracking
Configuration for vlan 1 on ap (this configuration run)
interface vlan1
description "Virtual Interface for LAN by Wizard"
ip address 169.254.221.40/16
ip address zeroconf secondary
ip dhcp client request options all
interface ge1
switchport mode trunk
switchport trunk allowed vlan 1,5
switchport trunk native vlan 5
switchport trunk native tagged
interface pppoe1
interface radio1
wlan wlan1 bss 1 primary
interface radio2
Configuration for vlan 5 on ap (this configuration don't run)
* X450e-48p.35 # sh vlan "config"
VLAN Interface with name config created by user
Admin State: Enabled Tagging: 802.1Q Tag 5
Description: None
IPv6: None
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
Ports: 4. (Number of active ports=3)
Untag: *3,
Tag: *17, *19
interface vlan5
description "config"
interface ge1
interface pppoe1
interface radio1
interface vlan5
description config interface radio2
INFORMATION AP
AP7522 version 5.9.2.0-032R
Copyright (c) 2004-2018 Extreme Networks, Inc. All rights reserved.
Booted from primary
ap7522-A8DD28 uptime is 0 days, 07 hours 06 minutes
CPU is ARMv7, No. of CPUs 2
Base ethernet MAC address is B8-50-01-A8-XX-XX
System serial number is XXXXXXXXXXXXXX
Model number is AP-7522-67030-WR
INFORMATION SWITCH
SysName: X450e-48p
SysLocation:
SysContact: support@extremenetworks.com, +1 888 257 3000
System MAC: 00:04:96:36:XX:XX
System Type: X450e-48p
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Tue May 21 13:28:11 2019
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Tue May 14 08:35:09 2019
Boot Count: 64
Next Reboot: None scheduled
System UpTime: 7 days 4 hours 53 minutes 2 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 15.3.1.4
patch1-19
Secondary ver: 12.6.5.2
6 REPLIES 6
‎05-29-2019 08:03 AM
hi,
i've check configuration on AP. this one is connected to ports 19 has 'switchport trunk native tagged' But result is the same.
code:
* X450e-48p.4 # sh fdb ports 3,17,19
Mac Vlan Age Flags Port / Virtual Port List
00:0e:c6:d1:XX:XX Default(0001) 0143 d m 3
b8:50:01:a8:ZZ:ZZ Default(0001) 0136 d m 17
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC, i - IP,
x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egress Blackhole,
b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN translation,
D - drop packet, h - Hardware Aging, o - IEEE 802.1ah Backbone MAC,
S - Software Controlled Deletion, r - MSRP
Total: 9 Static: 0 Perm: 0 Dyn: 9 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
‎05-28-2019 08:57 AM
First I'd like to walk with you through the VLAN 1 approach. As you can see only AP on port 17 is seen by the switch in the VLAN, and AP on port 19 isn't. You would have to review port-19-AP's interface config to make it be seen in VLAN Default on EXOS.
BTW, if you don't mind having untagged ports with APs connected to them, you don't have to change VLAN settings on an AP, it can go to whatever VLAN you wish but having ports untagged in that VLAN on EXOS. Otherwise, let's work it out. For VLAN 1 design, make sure your AP connected to port 19 has 'switchport trunk native tagged' so you should be able to see it when doing 'show fdb' on EXOS.
Kind regards,
Tomasz
Kind regards,
Tomasz
‎05-28-2019 07:22 AM
code:
hi, i've progress on different part on my project .But i'm stuck on problem vlan tag between ap7522 and switch summit x450e-48p
‎05-22-2019 08:29 AM
Yes, i commit my AP config after changing the interfaces' settings.
ports 3 connected to computer (untagged)
port 17 connected to AP (tagged) (Virtual controller)
port 19 connected to AP (tagged) (slave)
vlan 5 configuration ( i try to reach the AP.But it's doesn't work )
Vlan 1 configuration (i reache the AP . But the AP on ports 19 it's not adopted by VC)
code:
* X450e-48p.2 # sh fdb ports 3,17,19
00:0e:c6:d1:XX:XX config(0005) 0034 d m 3
Total: 1 Static: 0 Perm: 0 Dyn: 1 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
code:
* X450e-48p.14 # sh fdb ports 3,17,19
00:0e:c6:d1:XX:XX Default(0001) 0008 d m 3
b8:50:01:a8:ZZ:ZZ Default(0001) 0010 d m 17
x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egss Blackhole,
b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN anslation,
Total: 2 Static: 0 Perm: 0 Dyn: 2 Dropped: 0 Locked: 0 Locked with Timeou 0
FDB Aging time: 300
