‎05-21-2019 02:55 PM
Configuration for vlan 1 on switch (this configuration run)
* X450e-48p.34 # sh vlan "Default"
VLAN Interface with name Default created by user
Admin State: Enabled Tagging: 802.1Q Tag 1
Description: None
Virtual router: VR-Default
IPv4 Forwarding: Disabled
IPv4 MC Forwarding: Disabled
IPv6 Forwarding: Disabled
IPv6 MC Forwarding: Disabled
IPv6: None
STPD: s0(Disabled,Auto-bind)
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
QosProfile: None configured
Egress Rate Limit Designated Port: None configured
Flood Rate Limit QosProfile: None configured
Ports: 2. (Number of active ports=3)
Untag: *3,
Tag: *17, *19
Flags: (*) Active, (!) Disabled, (g) Load Sharing port
(b) Port blocked on the vlan, (m) Mac-Based port
(a) Egress traffic allowed for NetLogin
(u) Egress traffic unallowed for NetLogin
(t) Translate VLAN tag for Private-VLAN
(s) Private-VLAN System Port, (L) Loopback port
(e) Private-VLAN End Point Port
(x) VMAN Tag Translated port
(G) Multi-switch LAG Group port
(H) Dynamically added by MVRP
(U) Dynamically added uplink port
(V) Dynamically added by VM Tracking
Configuration for vlan 1 on ap (this configuration run)
interface vlan1
description "Virtual Interface for LAN by Wizard"
ip address 169.254.221.40/16
ip address zeroconf secondary
ip dhcp client request options all
interface ge1
switchport mode trunk
switchport trunk allowed vlan 1,5
switchport trunk native vlan 5
switchport trunk native tagged
interface pppoe1
interface radio1
wlan wlan1 bss 1 primary
interface radio2
Configuration for vlan 5 on ap (this configuration don't run)
* X450e-48p.35 # sh vlan "config"
VLAN Interface with name config created by user
Admin State: Enabled Tagging: 802.1Q Tag 5
Description: None
IPv6: None
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
Ports: 4. (Number of active ports=3)
Untag: *3,
Tag: *17, *19
interface vlan5
description "config"
interface ge1
interface pppoe1
interface radio1
interface vlan5
description config interface radio2
INFORMATION AP
AP7522 version 5.9.2.0-032R
Copyright (c) 2004-2018 Extreme Networks, Inc. All rights reserved.
Booted from primary
ap7522-A8DD28 uptime is 0 days, 07 hours 06 minutes
CPU is ARMv7, No. of CPUs 2
Base ethernet MAC address is B8-50-01-A8-XX-XX
System serial number is XXXXXXXXXXXXXX
Model number is AP-7522-67030-WR
INFORMATION SWITCH
SysName: X450e-48p
SysLocation:
SysContact: [email protected], +1 888 257 3000
System MAC: 00:04:96:36:XX:XX
System Type: X450e-48p
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Tue May 21 13:28:11 2019
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Tue May 14 08:35:09 2019
Boot Count: 64
Next Reboot: None scheduled
System UpTime: 7 days 4 hours 53 minutes 2 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 15.3.1.4
patch1-19
Secondary ver: 12.6.5.2
‎05-21-2019 08:14 PM
‎05-21-2019 06:44 PM
