Problem with Cisco and Extreme Switch
rstoccom
Hello everyone!
Hope you all are fine and healthy.
I have been working with the configuration of some Cisco APs connected to a Cisco switch / Switch Extreme for three days. However, so far, no success in this task. As a result, I decided to raise my hand and ask for help. I will leave attached a quite simple (mspaint productions lol) topology here to exemplify my scenario.
The scenario is quite simple too, we need to configure some Cisco APs (model aironet serie 18XX), all of these APs will be connected to Switch Cisco. These APs have a built-in controller, called Mobility Express. In theory, all we need is to configure the first AP / Controller and the rest will be connected automatically during the joining process. So guess what? For some reason, the join just doesn't work.
Some points.
- If the APs are on the same switch. OK, the joining process works without any problems.
- If the APs are connected to another switch (going through Extreme uplink between switchs), the process does not work. Both switchs are reachable, we can ping each other, the gateway, servers, etc.
- We are on the same subnet, so there is not a L3/firewall between.
- Just for testing proposal, If I replace the Extreme with a conventional switch (e.g: tplink), everything works fine, the joining process works with no erros.
- Switch Extreme does not have any special configuration, standard configuration (ports auto neg, speed full, access mode). (Although there are some VLANs configured).
- I have already disabled the flowcontrol, broadcast flooding settings. Unsuccessfully.
- We have already made contact with Cisco, however, Cisco is unable to help due to the connection switch being Extreme.
Everything indicates that for some reason Extreme is blocking this communication during the AP's JOIN process. Maybe broadcast, dtls packets… well, to be honest, I have no more ideas.
Would anyone have any suggestions for solving this puzzle? I really appreciate any help or even an idea.
Thank you all.
14 REPLIES 14
rstoccom
@Miguel-Angel RODRIGUEZ-GARCIA
Hello Miguel.
I guess for some reason VRRP multicast is not working.
I’ve captured the packages and the AP detects VRRP and after that, the join process starts.
I don't have VRRP on this Extreme device, no make sense.
Do you have any idea?
rstoccom
Hello Miguel.
I don't have sure, how can I check it ?
But I guess I’m not using VRRP.
Miguel-Angel_RO
Valued Contributor II
rstoccom,
Just for a test I would disable the igmp snooping on the VLAN 1 on the EXOS switch. APs are often using some kind of multicast to discover neighbors in a legacy way.
Do you use VRRP on the VLAN 1 on the EXOS?
Mig
rstoccom
Hello CWurm.
Yes, we are using default VLAN1. I will check that, maybe disable spaningtree on uplink ports (Extreme).
Yes, connecting a computer on each switch cisco will working just fine
Thank you for you reply.
CWurm
Contributor
Hi rstoccom,
are you using VLAN 1 (Default) on the Extreme Switch? Extreme has spanning tree enabled by default on VLAN 1 which could possibly interfere with the STP on your Cisco switches.
Also have you tried to connect a clients (PC/notebook/...) to each Cisco switch and ping each other through the Extreme switch to rule out a general connectivity issue between the Ciscos and the Extreme switch?
Kind regards
Christian
