Problem with CPU and memory monitoring (MIBs)
eyeV
New Contributor III
Hi everybody.
I have some troubles with CPU and memory monitoring on the Solarwinds monitoring system. I've gotten interface statistics, sysname, sysdescription, but I haven't found CPU and memory information.
Then I try to find ExtremeXOS MIBs, but unfortunately I haven't found it too.
Where can I find XOS MIBs? Can you give me advice about SNMP monitoring?
13 REPLIES 13
treese
Contributor
Is there a config or concept guide on this one. I have summit switches and 8810's that need I want more viability using Solarwinds.
Ok Thank you.
Drew_C
Valued Contributor III
The MIB file is somewhat tied to each EXOS version. If you have access to esupport/extranet, you should be able to download it for your particular version. If you can't find it, let me know what version your EXOS gear is running and I can get it to you.
Once it's imported, you should be able to browse and search for specific areas of interest.
I'm not aware of a specific SNMP guide, though one may exist - sorry.
I believe so. They have a basic set but always seems like something is missing.
Is there a config guide or document for all the Extreme snmp OID's?
