Hi all, We have had a problem with EAPS that has caused a high level CPU of the switches an the increase of traffic through the rings. A continuation I show the picture of the EAPS.
External plant had a maintenance which involved that the links in red (the shared port )got down, after two or three hours the link between SJL -LN got up and the problem started, the cpu increase and the traffic also.
These are the logs (SBJExtr had 30 minutes more):
LN_Extreme.59 # show log 09/20/2017 02:04:03.63 EAPSD FLX_EAPS_MirSjlLnSbj - 49 state transition from Up => Down
09/20/2017 02:04:03.63 EAPS Shared-port 50 - Segment-port 49 state transition from Up => Down
09/20/2017 02:04:03.62 Remove port 49 from aggregator
09/20/2017 02:04:03.62 Port 49 is Down, remove from aggregator 49
09/20/2017 02:04:03.62 Port 49 link down - Local fault
09/20/2017 01:44:10.04 Login passed for user admin through telnet (181.224.229.4)
09/20/2017 01:34:41.09 EAPS Shared-port 50 - Not processing Link-Down-Pdu, because linkId 11 matches our own
09/20/2017 01:34:41.09 EAPSD FLX_EAPS_MirSjlLnSbj - Received Link-Down-Pdu (MAC = 00:04:96:99:83:24)
09/20/2017 01:34:41.09 EAPSD FLX_EAPS_MirSjlLnSbj - Received RingDown-FlushFdb-Pdu (MAC = 00:04:96:99:9E:3E)
09/20/2017 01:34:41.07 EAPSD FLX_EAPS_MirSjlLnSbj - Link-Down State unchanged
09/20/2017 01:34:41.07 EAPSD FLX_EAPS_MirSjlLnSbj - 49 state transition from Down => Up
09/20/2017 01:34:41.06 EAPS Shared-port 50 - Segment-port 49 state transition from Down => Up
09/20/2017 01:34:41.06 Add port 49 to aggregator
09/20/2017 01:34:38.91 Port 49 link UP at speed 10 Gbps and full-duplex
SBJ-EXT_AGREG.10 # show log
09/20/2017 02:46:49.51 SNMP access from source 209.126.136.2 is denied by rule telnet_in. Dropping this Request.
09/20/2017 02:32:39.34 EAPS Shared-port 2 - Processing Link-Down-Pdu on segment-port 5
09/20/2017 02:32:39.34 EAPS Shared-port 5 - Segment-port 2 state transition from Up => Down
09/20/2017 02:32:39.34 EAPS Shared-port 5 - Processing Link-Down-Pdu on segment-port 2
09/20/2017 02:32:39.34 EAPSD FLX_EAPS_MirSjlLnSbj - Received Link-Down-Pdu (MAC = 00:04:96:99:9E:3E)
09/20/2017 02:03:17.58 EAPS Shared-port 5 - Segment-port 2 state transition from Down => Up
09/20/2017 02:03:16.79 EAPS Shared-port 2 - Processing Link-Down-Pdu on segment-port 5
09/20/2017 02:03:16.79 EAPSD FLX_EAPS_MirSjlLnSbj - Received Link-Down-Pdu (MAC = 00:04:96:99:9E:40)
09/20/2017 02:03:16.77 EAPSD FLX_EAPS_MirSjlLnSbj - Received RingDown-FlushFdb-Pdu (MAC = 00:04:96:99:9E:3E)
And the state of the eaps in the nodes LN and SJL are the next one.
LN_Extreme.75 # show eaps
EAPS Enabled: Yes
EAPS Fast-Convergence: Off
EAPS Display Config Warnings: Off
EAPS Multicast Add Ring Ports: Off
EAPS Multicast Send IGMP and MLD Query: On
EAPS Multicast Temporary Flooding: Off
EAPS Multicast Temporary Flooding Duration: 15 sec
Number of EAPS instances: 2
# EAPS domain configuration :
Domain State Mo En Pri Sec Control-Vlan VID Count Prio
FLX_EAPS_SbLnSmi Links-Down T Y 51 50 FLX_CONTROL_SbLnSMi (701 ) 132 N
FLX_EAPS_MirSjlLnSbj Links-Down T Y 49 50 FLX_control_MirSJLLNSBJ (412 ) 96 N
Flags : (!) CFM Down
LN_Extreme.76 #
LN_Extreme.76 # show eaps shared-port
EAPS shared-port count: 1
Link Domain Vlan RB RB
Shared-port Mode Id Up State count count Nbr State Id
50 Controller 11 Y Blocking 2 176 Yes None None
LN_Extreme.77 #
SBJ-EXT_AGREG.13 # show eaps shared-port
EAPS shared-port count: 2
2 Partner 10 Y Ready 3 442 Yes None None
5 Partner 11 Y Blocking 2 177 Yes None None
SBJ-EXT_AGREG.14 #
SBJ-EXT_AGREG.14 #
SBJ-EXT_AGREG.14 # show eaps
EAPS Enabled: Yes
EAPS Display Config Warnings: On
Number of EAPS instances: 4
FLX_EAPS-MiSaV Links-Up T Y 6 2 FLX_CONTROL_MiSaV (7 ) 274 N
FLX_EAPS-MiSaLi Links-Up T Y 4 2 FLX_Control_Mir-SBJ-Lin (413 ) 129 N
FLX_EAPS_SbLnSmi Links-Down T Y 5 10 FLX_Control_SbLnSMi (701 ) 132 N
FLX_EAPS_MirSjlLnSbj Links-Down T Y 5 2 FLX_control_MirSJLLNSBJ (412 ) 96 N
SBJ-EXT_AGREG.15 #
