routing between vlan
Alexey_shaverne
Hi! i have extreeeme 440t-g2-10ge. and this vlan cfg.
Default 1 10.1.5.254 /21 -f----------T--------------- ANY 7 /19 VR-Default
GuestWiFi1111 1111 10.111.111.2 /24 ---------------------------- ANY 3 /3 VR-Default
Mgmt 4095 10.1.5.151 /8 ---------------------------- ANY 0 /1 VR-Mgmt
PrintersVLAN 10 10.1.10.1 /23 -f-------------------------- ANY 3 /4 VR-Default
VoIPVLAN 20 10.1.20.2 /23 ---------------------------- ANY 3 /3 VR-Default
ServersVLAN 30 10.1.30.2 /23 ---------------------------- ANY 2 /2 VR-Default
and this route cfg
#s 10.1.0.0/16 10.1.5.31 1 UG---S-um--f- Default 135d:3h:28m:18s
#d 10.1.0.0/21 10.1.5.254 1 U------um--f- Default 156d:23h:3m:9s
#d 10.1.10.0/23 10.1.10.1 1 U------um--f- PrintersVLAN 140d:2h:42m:41s
#d 10.1.20.0/23 10.1.20.2 1 U------um--f- VoIPVLAN 0d:2h:56m:39s
#d 10.1.30.0/23 10.1.30.2 1 U------um--f- ServersVLAN 27d:21h:40m:15s
if I connect to the port (untagged) a laptop on which there is a server (VLAN), then it will receive settings for dhcp, but does not ping the gateway (VLAN interface). Accordingly, no equipment is pinged further either. How to solve this problem. Before I installed the latest firmware, everything worked. I don’t want to return the old one. There was a slower functioning web interface.
help me please!!!
9 REPLIES 9
Eric_Burke
New Contributor III
Try a "show iparp" on the extreme and make sure your devices/IP's are showing the vlan's you expect. Also do a "show fdb" and confirm the same for mac's alone. Can you ping the router from the switch virtual interfaces? You can force them to cross the same subnet "ping 10.1.20.1 from 10.1.20.2" or "ping 10.1.30.1 from 10.1.30.2". Should help you to isolate a bit more.
Alexey_shaverne
Eric, the MICROTIK router is a dhcp server. Each port on the router has its own vlan and interface, each bridge has a bridge, each bridge has dhcp servers with their pools. On the extreme, the same vlans are created. I am pinging the gateway on a microtic (10.1.20.1 or 10.1.30.1) from the commutator, but the devices that received the address (the phone and the computer do not respond).
Eric_Burke
New Contributor III
Can you be a bit more specific. Which port are you plugging in to with the station, which port is the server located on and which subnets does DHCP offer addresses for? What's the IP of that server? Can you paste the entire config?
Alexey_shaverne
yes, i do that and i have vlan cfg that
VoIPVLAN 20 10.1.20.2 /23 -f-------------------------- ANY 3 /3 VR-Default
ServersVLAN 30 10.1.30.2 /23 -f-------------------------- ANY 2 /2 VR-Defaul
Ole
do you have "ip forwarding" enabled on the vlan ip-interfaces?
